New interface
Reports (Research report)
Reflected BSDEs and robust optimal stopping for dynamic risk measures with jumps
Marie-Claire Quenez 1, 2 Agnès Sulem 2
2 MATHRISK - Mathematical Risk handling
Inria Paris-Rocquencourt, UPEM - Université Paris-Est Marne-la-Vallée, ENPC - École des Ponts ParisTech
Abstract : We study the optimal stopping problem for dynamic risk measures represented by Backward Stochastic Differential Equations (BSDEs) with jumps and its relation with reflected BSDEs (RBSDEs). We first provide general existence, uniqueness and comparison theorems for RBSDEs with jumps in the case of a RCLL adapted obstacle. We then show that the value function of the optimal stopping problem is characterized as the solution of an RBSDE. The existence of an optimal stopping time is obtained when the obstacle is left-upper semi-continuous along stopping times. Finally, robust optimal stopping problems related to the case with model ambiguity are investigated.
Document type :
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-00780175
Contributor : Martine Verneuille Connect in order to contact the contributor
Submitted on : Monday, January 28, 2013 - 4:09:18 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:01 AM
Long-term archiving on: : Saturday, April 1, 2017 - 11:56:36 AM
File
RR-8211.pdf
Identifiers
  • HAL Id : hal-00780175, version 2
Citation
Marie-Claire Quenez, Agnès Sulem. Reflected BSDEs and robust optimal stopping for dynamic risk measures with jumps. [Research Report] RR-8211, INRIA. 2013, pp.27. ⟨hal-00780175v2⟩
Share
Metrics
Record views
243
Files downloads
231
