New interface
Journal articles
Joint Spectral Radius, Dilation Equations, and Asymptotic Behavior of Radix-Rational Sequences
Abstract : Radix-rational sequences are solutions of systems of recurrence equations based on the radix representation of the index. For each radix-rational sequence with complex values we provide an asymptotic expansion, essentially in the scale N^α log^l N. The precision of the asymptotic expansion depends on the joint spectral radius of the linear representation of the sequence of first-order differences. The coefficients are Hölderian functions obtained through some dilation equations, which are usual in the domains of wavelets and refinement schemes. The proofs are ultimately based on elementary linear algebra.
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/hal-00780568
Contributor : Philippe Dumas Connect in order to contact the contributor
Submitted on : Thursday, January 24, 2013 - 12:56:24 PM
Last modification on : Friday, August 5, 2022 - 9:26:01 AM
Long-term archiving on: : Saturday, April 1, 2017 - 10:06:09 AM
File
LAA-Dumas-vHal.pdf
Identifiers
Collections
Citation
Philippe Dumas. Joint Spectral Radius, Dilation Equations, and Asymptotic Behavior of Radix-Rational Sequences. Linear Algebra and its Applications, 2013, 438 (5), pp.2107-2126. ⟨10.1016/j.laa.2012.10.013⟩. ⟨hal-00780568⟩
Share
Metrics
Record views
115
Files downloads
154
