Blocking : exploiting spatial locality for trace compaction, Proceedings of the ACM SIGMETRICS Conference on Measurement and Modeling of Computer Systems, 1990. ,
Branch trace compression for snapshot-based simulation, 2006 IEEE International Symposium on Performance Analysis of Systems and Software, 2006. ,
DOI : 10.1109/ISPASS.2006.1620787
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.71.5250
TCgen 2.0, ACM SIGARCH Computer Architecture News, vol.34, issue.3, 2006. ,
DOI : 10.1145/1152394.1152395
The VPC Trace-Compression Algorithms, IEEE Transactions on Computers, vol.54, issue.11, pp.1329-1344, 2005. ,
DOI : 10.1109/TC.2005.186
Automatic Generation of High-Performance Trace Compressors, International Symposium on Code Generation and Optimization, 2005. ,
DOI : 10.1109/CGO.2005.6
TPTS: A Novel Framework for Very Fast Manycore Processor Architecture Simulation, 2008 37th International Conference on Parallel Processing, 2008. ,
DOI : 10.1109/ICPP.2008.7
Statistical simulation: Adding efficiency to the computer designer's toolbox, IEEE Micro, vol.23, issue.5, pp.26-38, 2003. ,
DOI : 10.1109/MM.2003.1240210
PDATS Lossless Address Trace Compression For Reducing File Size And Access Time, Proceeding of 13th IEEE Annual International Phoenix Conference on Computers and Communications, 1994. ,
DOI : 10.1109/PCCC.1994.504117
FastMP : a multi-core simulation methodology, 2nd Annual Workshop on Modeling , Benchmarking and Simulation, 2006. ,
A first-order superscalar processor model Choosing representative slices of program execution for microarchitecture simulations : a preliminary application to the data stream, Proceedings of the 31st International Symposium on Computer Architecture IEEE 3rd Annual Workshop on Workload Characterization, 2000. ,
CPR: Composable performance regression for scalable multiprocessor models, 2008 41st IEEE/ACM International Symposium on Microarchitecture, 2008. ,
DOI : 10.1109/MICRO.2008.4771797
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.152.256
Pin : building customized program analysis tools with dynamic instrumentation, Proceedings of the ACM SIGPLAN conference on Programming Language Design and Implementation, 2005. ,
Locality-based online trace compression, IEEE Transactions on Computers, vol.53, issue.6, pp.723-731, 2004. ,
DOI : 10.1109/TC.2004.12
METRIC, ACM Transactions on Programming Languages and Systems, vol.29, issue.2, 2007. ,
DOI : 10.1145/1216374.1216380
An efficient single-pass trace compression technique utilizing instruction streams, ACM Transactions on Modeling and Computer Simulation, vol.17, issue.1, 2007. ,
AC/DC: an adaptive data cache prefetcher, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., 2004. ,
DOI : 10.1109/PACT.2004.1342548
Identifying hierarchical structure in sequences : a linear-time algorithm, Journal of Artificial Intelligence Research, vol.7, 1997. ,
Dynamic phase analysis for cycle-close trace generation, Proceedings of the 3rd IEEE/ACM/IFIP international conference on Hardware/software codesign and system synthesis, CODES+ISSS '05, 2005. ,
DOI : 10.1145/1084834.1084913
Techniques for compressing program address traces, Proceedings of the 27th annual international symposium on Microarchitecture , MICRO 27, 1994. ,
DOI : 10.1145/192724.192728
Analysis of cache replacement algorithms, 1985. ,
Mache : no-loss trace compaction, Proceedings of the ACM SIGMETRICS Conference on Measurement, and Modeling of Computer Systems, 1989. ,
DOI : 10.1145/75372.75382
URL : http://www.dtic.mil/get-tr-doc/pdf?AD=ADA619780
Prediction and Entropy of Printed English, Bell System Technical Journal, vol.30, issue.1, pp.50-64, 1951. ,
DOI : 10.1002/j.1538-7305.1951.tb01366.x
Automatically characterizing large scale program behavior, Proceedings of the 10th International Conference on Architectural Support for Programming Languages and Operating Systems, 2002. ,
DOI : 10.1145/605397.605403
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.118.6150
Discovering and exploiting program phases, IEEE Micro, vol.23, issue.6, pp.84-93, 2003. ,
DOI : 10.1109/MM.2003.1261391
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.58.4012
Phase tracking and prediction, Proceedings of the 30th International Symposium on Computer Architecture, 2003. ,
DOI : 10.1109/isca.2003.1207012
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.12.3639
Two Methods for the Efficient Analysis of Memory Address Trace Data, IEEE Transactions on Software Engineering, vol.3, issue.1, pp.94-101, 1977. ,
DOI : 10.1109/TSE.1977.233841
Efficient simulation of caches under optimal replacement with applications to miss characterization, Proceedings of the ACM SIGMETRICS Conference on Measurement and Modeling of Computer Systems, 1993. ,
Trace-driven memory simulation: a survey, ACM Computing Surveys, vol.29, issue.2, pp.128-170, 1997. ,
DOI : 10.1145/254180.254184
