High order marching schemes for the wave equation in complex geometry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2004
We present a new class of explicit marching schemes for the wave equation in complex geometry. They rely on a simple embedding of the domain in a uniform Cartesian grid, which allows for efficient and automatic implementation but creates irregular cells near the boundary. While existing explicit finite difference schemes are generally restricted in the size of the time step that can be taken by the dimensions of the smallest cell, the schemes described here are capable of taking time steps dictated by the uniform grid spacing. This should be of significant benefit in a wide variety of simulation efforts.
Fichier non déposé
hal-00781131 , version 1 (25-01-2013)
  • HAL Id : hal-00781131 , version 1
Jing-Rebecca Li, Leslie Greengard. High order marching schemes for the wave equation in complex geometry. Journal of Computational Physics, 2004, 198 (1), pp.295--309. ⟨hal-00781131⟩
132 Consultations
0 Téléchargements
