On the numerical solution of the heat equation I: Fast solvers in free space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2007
We describe a fast solver for the inhomogeneous heat equation in free space, following the time evolution of the solution in the Fourier domain. It relies on a recently developed spectral approximation of the free-space heat kernel coupled with the non-uniform fast Fourier transform. Unlike finite difference and finite element techniques, there is no need for artificial boundary conditions on a finite computational domain. The method is explicit, unconditionally stable, and requires an amount of work of the order O(NMlogN), where N is the number of discretization points in physical space and M is the number of time steps. We refer to the approach as the fast recursive marching (FRM) method.
hal-00781132 , version 1 (25-01-2013)
Jing-Rebecca Li, Leslie Greengard. On the numerical solution of the heat equation I: Fast solvers in free space. Journal of Computational Physics, 2007, 226 (2), pp.1891--1901. ⟨10.1016/j.jcp.2007.06.021⟩. ⟨hal-00781132⟩
190 Consultations
0 Téléchargements
