Towards Scalable Checkpoint Restart: A Collective Inline Memory Contents Deduplication Proposal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bogdan Nicolae
With increasing scale and complexity of supercomputing and cloud computing architectures, faults are becoming a frequent occurrence. For a large class of applications that run for a long time and are tightly coupled, Checkpoint-Restart (CR) is the only feasible method to survive failures. However, exploding checkpoint sizes that need to be dumped to storage pose a major scalability challenge, prompting the need to reduce the amount of checkpointing data. This paper contributes with a novel collective memory contents deduplication scheme that attempts to identify and eliminate duplicate memory pages before they are saved to storage. Unlike previous approaches that concentrate on the checkpoints of the same process, our approach identifies duplicate memory pages shared by different processes (regardless whether on the same or different node). We show both how to achieve such a global deduplication in a scalable fashion and how to leverage it effectively to optimize the data layout in such way that it minimizes I/O bottlenecks. Large scale experiments show significant reduction of storage space consumption and performance overhead compared to several state-of-art approaches, both in synthetic benchmarks and for a real life high performance computing application.
paper.pdf (177.46 Ko) Télécharger le fichier
hal-00781532 , version 1 (27-01-2013)
hal-00781532 , version 2 (02-06-2013)
  • HAL Id : hal-00781532 , version 1
Bogdan Nicolae. Towards Scalable Checkpoint Restart: A Collective Inline Memory Contents Deduplication Proposal. IPDPS '13: The 27th IEEE International Parallel and Distributed Processing Symposium, May 2013, Boston, United States. ⟨hal-00781532v1⟩
274 Consultations
355 Téléchargements
