Building reconstruction from a single DEM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Florent Lafarge
  • Fonction : Auteur
  • PersonId : 833647
Xavier Descombes
Josiane Zerubia
  • Fonction : Auteur
  • PersonId : 833424
We present a new approach for building reconstruction from a single Digital Elevation Model (DEM). It treats buildings as an assemblage of simple urban structures extracted from a library of 3D parametric blocks (like a LEGO set). This method works on various data resolutions such as 0.7 m satellite and 0.1 m aerial DEMs and allows us to obtain 3D representations with various levels of detail. First, the 2D supports of the urban structures are extracted either interactively or automatically. Then, 3D blocks are placed on the 2D supports using a Gibbs model. A Bayesian decision finds the optimal configuration of 3D blocks using a RJMCMC sampler. Experimental results on complex buildings and dense urban areas are presented using data at various resolutions
2008_lafarge_cvpr08.pdf (2.95 Mo) Télécharger le fichier
hal-00781733 , version 1 (28-01-2013)
  • HAL Id : hal-00781733 , version 1
Florent Lafarge, Xavier Descombes, Josiane Zerubia, Marc Pierrot-Deseilligny. Building reconstruction from a single DEM. Computer Vision and Pattern Recognition (CVPR), Jun 2008, Anchorage, United States. ⟨hal-00781733⟩
237 Consultations
360 Téléchargements
