Abstract : The Internet of Things embodies a wide spectrum of machines ranging from sensors powered by 8-bit microcontrollers to devices powered by processors roughly equivalent to those found in entry-level smartphones. Neither traditional operating systems (OS) currently running on Internet hosts, nor typical OS for sensor networks are capable to fulfill all at once the diverse requirements of such a wide range of devices. Hence, in order to avoid redundant developments and maintenance costs of IoT products, a novel, unifying type of OS is needed. The following analyzes requirements such an OS should fulfill and introduces RIOT, an OS satisfying these demands.
https://hal.inria.fr/hal-00781769 Contributor : Emmanuel BaccelliConnect in order to contact the contributor Submitted on : Monday, January 28, 2013 - 1:09:27 PM Last modification on : Friday, February 4, 2022 - 3:14:03 AM Long-term archiving on: : Monday, June 17, 2013 - 4:12:23 PM
Emmanuel Baccelli, Oliver Hahm, Mesut Günes, Matthias Wählisch, Thomas C. Schmidt. OS for the IoT - Goals, Challenges, and Solutions. Workshop Interdisciplinaire sur la Sécurité Globale (WISG2013), Jan 2013, Troyes, France. ⟨hal-00781769⟩
