LIDAR WAVEFORM MODELING USING A MARKED POINT PROCESS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Lidar waveforms are 1D signal consisting of a train of echoes where each of them correspond to a scattering target of the Earth surface. Modeling these echoes with the appropriate parametric function is necessary to retrieve physical information about these objects and characterize their properties. This paper presents a marked point process based model to reconstruct a lidar signal in terms of a set of parametric functions. The model takes into account both a data term which measures the coherence between the models and the waveforms, and a regularizing term which introduces physical knowledge on the reconstructed signal. We search for the best configuration of functions by performing a Reversible Jump Markov Chain Monte Carlo sampler coupled with a simulated annealing. Results are finally presented on different kinds of signals in urban areas.
2009_icip.pdf (3.69 Mo) Télécharger le fichier
hal-00781804 , version 1 (28-01-2013)
  • HAL Id : hal-00781804 , version 1
Clément Mallet, Florent Lafarge, Frédéric Bretar, Uwe Soergel, Christian Heipke. LIDAR WAVEFORM MODELING USING A MARKED POINT PROCESS. International Conference on Image Processing (ICIP), Nov 2009, Cairo, Egypt. ⟨hal-00781804⟩
362 Consultations
230 Téléchargements
