Towards connected filtering based on component-graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In recent works, a new notion of component-graph has been introduced to extend the data structure of component-tree –and the induced antiextensive filtering methodologies– from grey-level images to multivalued ones. In this article, we briefly recall the main structural key-points of component-graphs, and we present the initial algorithmic results that open the way to the actual development of component-graph-based antiextensive filtering procedures.
Naegel_ISMM_2013.pdf (2.33 Mo) Télécharger le fichier
Naegel ISMM 2013 Poster.pdf (683.71 Ko) Télécharger le fichier
hal-01695064 , version 1 (28-02-2018)
Benoît Naegel, Nicolas Passat. Towards connected filtering based on component-graphs. International Symposium on Mathematical Morphology (ISMM), 2013, Uppsala, Sweden. pp.350-361, ⟨10.1007/978-3-642-38294-9_30⟩. ⟨hal-01695064⟩
198 Consultations
332 Téléchargements
