The transitive reduction of a directed graph, SIAM J. Comput, vol.1, issue.2, pp.131-137, 1972. ,
Geometric algebra colour image representations and derived total orderings for morphological operators-Part I: Colour quaternions, J. Vis. Commun. Image R, vol.21, issue.1, pp.33-48, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00835974
A comparative study on multivariate mathematical morphology, Pattern Recogn, vol.40, pp.2914-2929, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00512660
Effective component tree computation with application to pattern recognition in astronomical imaging, ICIP, pp.41-44, 2007. ,
Extending the tree of shapes on colors, 2012. ,
Watershed cuts: Thinnings, shortest path forests, and topological watersheds, IEEE Trans. Pattern Anal. Mach. Intell, vol.32, issue.5, pp.925-939, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00729346
Morphological operators for image sequences, Comp. Vis. Imag. Under, vol.62, issue.3, pp.326-346, 1995. ,
Theoretical aspects of gray level morphology, IEEE Trans. Pattern Anal. Mach. Intell, vol.13, issue.6, pp.568-592, 1991. ,
Connected filtering and segmentation using component trees, Comp. Vis. Imag. Under, vol.75, issue.3, pp.215-228, 1999. ,
Scale-space from a level lines tree, J. Vis. Commun. Image R, vol.11, issue.2, pp.224-236, 2000. ,
Component-trees and multivalued images: A comparative study, ISMM, vol.5720, pp.261-171, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00412965
Building the component tree in quasi-linear time, IEEE Trans. Image Proc, vol.15, issue.11, pp.3531-3539, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00622110
An extension of component-trees to partial orders, ICIP, pp.3981-3984, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01695031
Component-trees and multivalued images: Structural properties, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00611714
Morphology on label images: Flat-type operators and connections, J. Math. Imaging Vis, vol.22, issue.2, pp.283-307, 2005. ,
Binary partition tree as an efficient representation for image processing, segmentation and information retrieval, IEEE Trans. Image Proc, vol.9, issue.4, pp.561-576, 2000. ,
Anti-extensive connected operators for image and sequence processing, IEEE Trans. Image Proc, vol.7, issue.4, pp.555-570, 1998. ,
Constrained connectivity for hierarchical image partitioning and simplification, IEEE Trans. Pattern Anal. Mach. Intell, vol.30, issue.7, pp.1132-1145, 2008. ,
Connected shape-size pattern spectra for rotation and scale-invariant classification of gray-scale images, IEEE Trans. Pattern Anal. Mach. Intell, vol.29, issue.2, pp.272-285, 2007. ,
Supervised ordering in R p : Application to morphological processing of hyperspectral images, IEEE Trans. Image Proc, vol.20, issue.11, pp.3301-3308, 2011. ,
Concurrent computation of attribute filters on shared memory parallel machines, IEEE Trans. Pattern Anal. Mach. Intell, vol.30, issue.10, pp.1800-1813, 2008. ,
Morphological filtering in shape spaces: Applications using tree-based image representations, ICPR, pp.485-488, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00714847
