Swarm robot synchronization using RFID tags
Giulio Zecca 1 Paul Couderc 1 Michel Banâtre 1 Roberto Beraldi 2
1 ACES - Ambient computing and embedded systems
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : The last progress in the pervasive computing field has led to the distribution of knowledge and computational power in the environment, rather than condensing it in a single, powerful entity. This allows agents to behave like insects in a swarm, that can fulfil a task communicating directly or indirectly among them. Following this vision of Ambient Intelligence, our work proposes a straightforward solution to coordinate a swarm of robots that have low computational capabilities. All the information and instructions are found in RFID tags that are used as a pervasive memory distributed in the environment. These robots exploit ubiquitous computing to make a formation in space, synchronise with team mates in the same zone, and finally complete a cooperative task. Before implementing the solution in a real scenario, we show the validation of our algorithm in a simulation environment.
Type de document :
Communication dans un congrès
IEEE. PerCom 2009 : Seventh Annual IEEE International Conference on Pervasive Computing and Communications, Mar 2009, Galveston, Texas, United States. pp.1-4, 2009, 〈10.1109/PERCOM.2009.4912788〉
Liste complète des métadonnées
https://hal.inria.fr/hal-00782237
Contributeur : Ist Rennes <>
Soumis le : mardi 29 janvier 2013 - 13:34:08
Dernière modification le : jeudi 11 janvier 2018 - 06:20:08
Collections
Citation
Giulio Zecca, Paul Couderc, Michel Banâtre, Roberto Beraldi. Swarm robot synchronization using RFID tags. IEEE. PerCom 2009 : Seventh Annual IEEE International Conference on Pervasive Computing and Communications, Mar 2009, Galveston, Texas, United States. pp.1-4, 2009, 〈10.1109/PERCOM.2009.4912788〉. 〈hal-00782237〉
Métriques
Consultations de la notice
283
