New interface
Conference papers
New genetic operators in the fly algorithm: application to medical PET image reconstruction
Abstract : Our reconstruction method is based on a cooperative coevolution strategy (also called Parisian evolution): the "fly algorithm". Each fly is a 3D point that mimics a positron emitter. The flies' position is progressively optimised using evolutionary computing to closely match the data measured by the imaging system. The performance of each fly is assessed using a "marginal evaluation" based on the positive or negative contribution of this fly to the performance of the population. Using this property, we propose a "thresholded-selection" method to replace the classical tournament method. A mitosis operator is also proposed. It is triggered to automatically increase the population size when the number of flies with negative fitness becomes too low.
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-00783832
Contributor : Evelyne Lutton Connect in order to contact the contributor
Submitted on : Friday, February 1, 2013 - 5:27:05 PM
Last modification on : Tuesday, October 25, 2022 - 4:16:48 PM
Long-term archiving on: : Monday, June 17, 2013 - 6:22:38 PM
File
Vidal2010EvoIASP.pdf
Identifiers
  • HAL Id : hal-00783832, version 1
Citation
Franck P. Vidal, Jean Louchet, Jean-Marie Rocchisani, Evelyne Lutton. New genetic operators in the fly algorithm: application to medical PET image reconstruction. EVOIASP, Evolutionary Computation in Image Analysis and Signal Processing, EvoApplications 2010, Apr 2010, Istambul, Turkey. ⟨hal-00783832⟩
Share
Metrics
Record views
213
Files downloads
300
