Maximum expected accuracy structural neighbors of an RNA secondary structure. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BMC Bioinformatics Année : 2012
BACKGROUND: Since RNA molecules regulate genes and control alternative splicing by allostery, it is important to develop algorithms to predict RNA conformational switches. Some tools, such as paRNAss, RNAshapes and RNAbor, can be used to predict potential conformational switches; nevertheless, no existent tool can detect general (i.e., not family specific) entire riboswitches (both aptamer and expression platform) with accuracy. Thus, the development of additional algorithms to detect conformational switches seems important, especially since the difference in free energy between the two metastable secondary structures may be as large as 15-20 kcal/mol. It has recently emerged that RNA secondary structure can be more accurately predicted by computing the maximum expected accuracy (MEA) structure, rather than the minimum free energy (MFE) structure. RESULTS: Given an arbitrary RNA secondary structure S₀ for an RNA nucleotide sequence a = a₁,..., a(n), we say that another secondary structure S of a is a k-neighbor of S₀, if the base pair distance between S₀ and S is k. In this paper, we prove that the Boltzmann probability of all k-neighbors of the minimum free energy structure S₀ can be approximated with accuracy ε and confidence 1 - p, simultaneously for all 0 ≤ k < K, by a relative frequency count over N sampled structures, provided that N>N(ε,p,K)=Φ⁻¹(p/2K)²/4ε², where Φ(z) is the cumulative distribution function (CDF) for the standard normal distribution. We go on to describe the algorithm RNAborMEA, which for an arbitrary initial structure S₀ and for all values 0 ≤ k < K, computes the secondary structure MEA(k), having maximum expected accuracy over all k-neighbors of S₀. Computation time is O(n³ * K²), and memory requirements are O(n² * K). We analyze a sample TPP riboswitch, and apply our algorithm to the class of purine riboswitches. CONCLUSIONS: The approximation of RNAbor by sampling, with rigorous bound on accuracy, together with the computation of maximum expected accuracy k-neighbors by RNAborMEA, provide additional tools toward conformational switch detection. Results from RNAborMEA are quite distinct from other tools, such as RNAbor, RNAshapes and paRNAss, hence may provide orthogonal information when looking for suboptimal structures or conformational switches. Source code for RNAborMEA can be downloaded from http://sourceforge.net/projects/rnabormea/ or http://bioinformatics.bc.edu/clotelab/RNAborMEA/.
hal-00783859 , version 1 (01-02-2013)
Peter Clote, Feng Lou, William A Lorenz. Maximum expected accuracy structural neighbors of an RNA secondary structure.. BMC Bioinformatics, 2012, 13 Suppl 5, pp.S6. ⟨10.1186/1471-2105-13-S5-S6⟩. ⟨hal-00783859⟩
176 Consultations
0 Téléchargements
