The contraction rate in Thompson part metric of order-preserving flows on a cone - application to generalized Riccati equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Differential Equations Année : 2014
We give a formula for the Lipschitz constant in Thompson's part metric of any order-preserving flow on the interior of a (possibly infinite dimensional) closed convex pointed cone. This provides an explicit form of a characterization of Nussbaum concerning non order-preserving flows. As an application of this formula, we show that the flow of the generalized Riccati equation arising in stochastic linear quadratic control is a local contraction on the cone of positive definite matrices and characterize its Lipschitz constant by a matrix inequality. We also show that the same flow is no longer a contraction in other natural Finsler metrics on this cone, including the standard invariant Riemannian metric. This is motivated by a series of contraction properties concerning the standard Riccati equation, established by Bougerol, Liverani, Wojtowski, Lawson, Lee and Lim: we show that some of these properties do, and that some other do not, carry over to the generalized Riccati equation.
hal-00783972 , version 1 (02-02-2013)
Stéphane Gaubert, Zheng Qu. The contraction rate in Thompson part metric of order-preserving flows on a cone - application to generalized Riccati equations. Journal of Differential Equations, 2014, 256 (8), pp.2902-2948. ⟨10.1016/j.jde.2014.01.024⟩. ⟨hal-00783972⟩
279 Consultations
0 Téléchargements
