Homogenization and concentration for a diffusion equation with large convection in a bounded domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Functional Analysis Année : 2012
We consider the homogenization of a non-stationary convection–diffusion equation posed in a bounded domain with periodically oscillating coefficients and homogeneous Dirichlet boundary conditions. Assuming that the convection term is large, we give the asymptotic profile of the solution and determine its rate of decay. In particular, it allows us to characterize the “hot spot”, i.e., the precise asymptotic location of the solution maximum which lies close to the domain boundary and is also the point of concentration. Due to the competition between convection and diffusion, the position of the “hot spot” is not always intuitive as exemplified in some numerical tests.
APP-CD-Omega-09-09-2011.pdf (6.8 Mo) Télécharger le fichier
hal-00784043 , version 1 (05-02-2020)
Grégoire Allaire, I. Pankratova, Andrey Piatnitski. Homogenization and concentration for a diffusion equation with large convection in a bounded domain. Journal of Functional Analysis, 2012, 262 (1), pp.300-330. ⟨10.1016/j.jfa.2011.09.014⟩. ⟨hal-00784043⟩
126 Consultations
56 Téléchargements
