Damage and fracture evolution in brittle materials by shape optimization methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2011
This paper is devoted to a numerical implementation of the Francfort-Marigo model of damage evolution in brittle materials. This quasi-static model is based, at each time step, on the minimization of a total energy which is the sum of an elastic energy and a Griffith-type dissipated energy. Such a minimization is carried over all geometric mixtures of the two, healthy and damaged, elastic phases, respecting an irreversibility constraint. Numerically, we consider a situation where two well-separated phases coexist, and model their interface by a level set function that is transported according to the shape derivative of the minimized total energy. In the context of interface variations (Hadamard method) and using a steepest descent algorithm, we compute local minimizers of this quasi-static damage model. Initially, the damaged zone is nucleated by using the so-called topological derivative. We show that, when the damaged phase is very weak, our numerical method is able to predict crack propagation , including kinking and branching. Several numerical examples in 2d and 3d are discussed.
Article_Damage-rev6.pdf (5.21 Mo) Télécharger le fichier
hal-00784048 , version 1 (04-02-2020)
  • HAL Id : hal-00784048 , version 1
Grégoire Allaire, François Jouve, Nicolas van Goethem. Damage and fracture evolution in brittle materials by shape optimization methods. Journal of Computational Physics, 2011, 230 (12), pp.5010--5044. ⟨hal-00784048⟩
261 Consultations
245 Téléchargements
