On the use of embedded discontinuity elements with crack path continuity for mode-I and mixed-mode fracture, Engineering Fracture Mechanics, vol.69, pp.661-686, 2002. ,
Continuity of the Darcy's law in the low-volume fraction limit, Ann. Scuola Norm. Sup. Pisa, vol.18, pp.475-499, 1991. ,
, Conception optimale de structures, Collection: Mathématiques et Applications, vol.58, 2007.
Simulation numérique de l'endommagementà l'aide du modèle Francfort-Marigo, ESAIM Proceedings, vol.3, pp.1-9, 1998. ,
Structural optimization using sensitivity analysis and a level-set method, J. Comput. Phys, vol.194, issue.1, pp.363-393, 2004. ,
Structural optimization using topological and shape sensitivity via a level set method, Control and Cybernetics, vol.34, pp.59-80, 2005. ,
A level set method for the numerical simulation of damage evolution, Proceedings of ICIAM 2007 Zürich, pp.3-22, 2009. ,
Approximation of functionals depending on jumps by elliptic functionals via ?-convergence, Comm. Pure Appl. Math, vol.43, issue.8, pp.999-1036, 1990. ,
Reconstruction of small inhomogeneities from boundary measurements, Lecture notes in mathematics, 1846. ,
Complete asymptotic expansions of solutions of the system of elastostatics in the presence of an inclusion of small diameter and detection of an inclusion, J. Elasticity, vol.67, issue.2, pp.97-129, 2002. ,
An introduction to mathematics of emerging biomedical imaging, Collection: Mathématiques et Applications, vol.62, 2008. ,
Direct elastic imaging of a small inclusion, SIAM Journal on Imaging Sciences, vol.1, pp.169-187, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00654620
An optimal design problem with perimeter penalization, Calc. Var, vol.1, pp.55-69, 1993. ,
Arbitrary bidimensional finite strain crack propagation, Computational Mechanics, vol.45, issue.1, pp.61-75, 2009. ,
A thick level set approach to model evolving damage and transition to fracture, Proceedings of ECCM 2010, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01154912
Sensitivity of Darcy's law to discontinuities, Chinese Ann. Math. Ser. B, vol.24, issue.2, pp.205-214, 2003. ,
Quasiautomatic simulation of crack propagation for 2D LEFM problems, Engineering Fracture Mechanics, vol.55, pp.321-324, 1996. ,
Inverse problems in elasticity, Inverse Problems, vol.21, pp.1-50, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00111264
Enriched finite elements and level sets for damage tolerance assessment of complex structures, Engineering Fracture Mechanics, vol.73, issue.9, pp.1176-1201, 2006. ,
Numerical implementation of the variational formulation for quasi-static brittle fracture, Interfaces and free boundaries, vol.9, pp.411-430, 2007. ,
Numerical experiments in revisited brittle fracture, J. Mech. Phys. Solids, vol.48, issue.4, pp.797-826, 2000. ,
The variational approach to fracture, Journal of Elasticity, vol.91, p.5148, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00551079
?-convergence for stable states and local minimizers ,
Homogenization of surface and length energies for spin systems ,
Mécanique de la rupture fragile, 1983. ,
Incorporating topological derivatives into level set methods, J. Comp. Phys, vol.194, issue.1, pp.344-362, 2004. ,
Pointwise polarization tensor bounds, and applications to voltage perturbations caused by thin inhomogeneities, Asymptot. Anal, vol.50, issue.3-4, pp.175-204, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-02083816
Conception optimale ou identification de formes, calcul rapide de la dérivée de la fonction coût, Math. Model. Numer. Anal, vol.20, issue.3, pp.371-402, 1986. ,
Image segmentation by variational methods: Mumford and Shah functional and the discrete approximations, SIAM J. Appl. Math, vol.55, pp.827-863, 1995. ,
Crack initiation in brittle materials, Arch. Rat. Mech. Anal, vol.188, pp.309-349, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00381652
, Mathematical analysis and Numerical methods for science and technology, vol.2, 1985.
Les espaces du type de Beppo Levi, Ann. Inst. Fourier, Grenoble, vol.5, pp.305-370, 1955. ,
Bubble method for topology and shape optimization of structures, Structural Optimization, vol.8, pp.42-51, 1994. ,
A variational view of brittle damage evolution, Arch. Ration. Mech. Anal, vol.182, issue.1, pp.125-152, 2006. ,
Stable damage evolution in a brittle continuous medium, Eur. J. Mech., A/Solids, vol.12, issue.2, pp.149-189, 1993. ,
Revisiting brittle fracture as an energy minimization problem, J. Mech. Phys. Solids, vol.46, issue.8, pp.1319-1342, 1998. ,
The topological asymptotic for PDE systems: the elasticity case, SIAM J. Control Optim, vol.39, issue.6, pp.1756-1778, 2001. ,
Threshold-based Quasi-static Brittle Damage Evolution, Arch. Ration. Mech. Anal, vol.194, issue.2, pp.585-609, 2009. ,
Non-planar 3D crack growth by the extended finite element and level sets -Part I: Mechanical model, Int. J. Numer. Meth. Engng, vol.53, issue.11, pp.2549-2568, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-01007110
Non-planar 3D crack growth by the extended finite element and level sets -Part II: Level set update, Int. J. Numer. Meth. Engng, vol.53, issue.11, pp.2569-2586, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-01007111
Variation et optimisation de formes, Mathématiques et Applications, vol.48, 2005. ,
The determination of a discontinuity in a conductivity from a single boundary measurement, Inverse Problems, vol.14, issue.1, pp.67-82, 1998. ,
Critical points via Gamma-convergence: general theory and applications, Jour. Eur. Math. Soc, vol.11, pp.705-753, 2009. ,
Epsilon-stable quasi-static brittle fracture evolution, Comm. Pure Appl. Math ,
A level set method for the Mumford-Shah functional and fracture, SIAM J. Imag. Sci ,
Mécanique de la rupture fragile et ductile, 2003. ,
A finite element method for crack growth without remeshing, Int. J. Numer. Meth. Engng, vol.46, issue.1, pp.131-150, 1999. ,
Relaxation of an optimal design problem in fracture mechanics, 2010. ,
Etudes de problèmes d'optimal design, Lecture Notes in Computer Science, vol.41, pp.54-62, 1976. ,
A finite element approximation of the Griffith's model in fracture mechanics, Numer. Math, vol.95, pp.653-687, 2003. ,
Quasi-static crack propagation by Griffith's criterion, vol.3, pp.1895-1925, 2008. ,
Level set methods and dynamic implicit surfaces, Applied Mathematical Sciences, vol.153, 2003. ,
Front propagating with curvature dependent speed: algorithms based on Hamilton-Jacobi formulations, J. Comp. Phys, vol.78, pp.12-49, 1988. ,
Sensibilité de l'équation de la chaleur aux sauts de conductivité, C. R. Acad. Sci. Paris, Ser. I, vol.341, pp.333-337, 2005. ,
Optimal shape design for elliptic systems, 1984. ,
Mechanical transformations and discontinuities along a moving surface, J. Mech. Phys. Solids, vol.43, issue.1, pp.91-121, 1995. ,
URL : https://hal.archives-ouvertes.fr/hal-00092042
A remark on computing distance functions, J. Comp. Phys, vol.163, pp.51-67, 2000. ,
Gamma-Convergence of Gradient Flows and Application to Ginzburg-Landau, Comm. Pure Appl. Math, vol.57, pp.1627-1672, 2004. ,
Eigenfracture: an eigendeformation approach to variational fracture, Multiscale Model. Simul, vol.7, issue.1, pp.1237-1266, 2009. ,
Level set Methods and fast marching methods: evolving interfaces in computational geometry, fluid mechanics, computer vision and materials science, 1999. ,
On the topological derivative in shape optimization, SIAM J. Control Optim, vol.37, pp.1251-1272, 1999. ,
Introduction to shape optimization: shape sensitivity analysis, Springer Series in Computational Mathematics, vol.10, 1992. ,
Energy Methods in Non-Linear Mechanics, IPPT PAN and CoE AMAS, vol.11, 2004. ,
Crack nucleation sensitivity analysis, Math. Meth. Appl. Sc, vol.33, issue.16, 2010. ,
A level set method for structural topology optimization, Comput. Methods Appl. Mech. Engrg, vol.192, pp.227-246, 2003. ,
Incorporating topological derivatives into level set methods for structural topology optimization, Optimal shape design and modeling, pp.145-157, 2004. ,
