Diffractive behavior of the wave equation in periodic media: weak convergence analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annali di Matematica Pura ed Applicata Année : 2009
We study the homogenization and singular perturbation of the wave equation in a periodic media for long times of the order of the inverse of the period. We consider inital data that are Bloch wave packets, i.e., that are the product of a fast oscillating Bloch wave and of a smooth envelope function. We prove that the solution is approximately equal to two waves propagating in opposite directions at a high group velocity with envelope functions which obey a Schr\"{o}dinger type equation. Our analysis extends the usual WKB approximation by adding a dispersive, or diffractive, effect due to the non uniformity of the group velocity which yields the dispersion tensor of the homogenized Schr\"{o}dinger equation.
faible3.pdf (402.58 Ko) Télécharger le fichier
hal-00784060 , version 1 (04-08-2020)
Grégoire Allaire, M. Palombaro, J. Rauch. Diffractive behavior of the wave equation in periodic media: weak convergence analysis. Annali di Matematica Pura ed Applicata, 2009, 188, pp.561-590. ⟨10.1007/s10231-008-0089-y⟩. ⟨hal-00784060⟩
127 Consultations
49 Téléchargements
