Shape and topology optimization of the robust compliance via the level set method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2008
The goal of this paper is to study the so-called worst-case or robust optimal design problem for minimal compliance. In the context of linear elasticity we seek an optimal shape which minimizes the largest, or worst, compliance when the loads are subject to some unknown perturbations. We first prove that, for a fixed shape, there exists indeed a worst perturbation (possibly non unique) that we characterize as the maximizer of a nonlinear energy. We also propose a stable algorithm to compute it. Then, in the framework of Hadamard method, we compute the directional shape derivative of this criterion which is used in a numerical algorithm, based on the level set method, to find optimal shapes that minimize the worst-case compliance. Since this criterion is usually merely directionally differentiable, we introduce a semidefinite programming approach to select the best descent direction at each step of a gradient method. Numerical examples are given in 2-d and 3-d. Mathematics Subject Classification. 49Q10, 74P10, 74P15, 74P20.
grobust-ri.pdf (1.27 Mo) Télécharger le fichier
hal-00784065 , version 1 (04-08-2020)
Grégoire Allaire, Frédéric de Gournay, François Jouve. Shape and topology optimization of the robust compliance via the level set method. ESAIM: Control, Optimisation and Calculus of Variations, 2008, 14 (14), pp.43--70. ⟨10.1051/cocv:2007048⟩. ⟨hal-00784065⟩
196 Consultations
73 Téléchargements
