Experimental Assessment of the Reliability for Watermarking and Fingerprinting Schemes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue EURASIP Journal on Information Security Année : 2008
We introduce the concept of reliability in watermarking as the ability of assessing that a probability of false alarm is very low and below a given significance level. We propose an iterative and self-adapting algorithm which estimates very low probabilities of error. It performs much quicker and more accurately than a classical Monte Carlo estimator. The article finishes with applications to zero-bit watermarking (probability of false alarm, error exponent), and to probabilistic fingerprinting codes (probability of wrongly accusing a given user, code length estimation).
1687-417X-2008-414962.pdf (295.58 Ko) Télécharger le fichier
1687-417X-2008-414962.xml (2.42 Ko) Télécharger le fichier
Format : Autre
hal-00784458 , version 1 (26-07-2010)
hal-00784458 , version 2 (04-02-2013)
  • HAL Id : hal-00784458 , version 2
Frédéric Cérou, Teddy Furon, Arnaud Guyader. Experimental Assessment of the Reliability for Watermarking and Fingerprinting Schemes. EURASIP Journal on Information Security, 2008, 2008 (1), pp.414962. ⟨hal-00784458v2⟩
431 Consultations
305 Téléchargements
