Asummaryreview of vibration-based damage identification methods The Shock and Vibration Digest Vibration-based structural damage identification, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.30, issue.359 1778, pp.91-105, 1998. ,
Damage assessment of civil engineering structures by vibration monitoring, 2003. ,
Structural Health Monitoring Using Vibration Measurements and Engineering Insight, Journal of Mechanical Design, vol.117, issue.B, pp.214-221, 1995. ,
DOI : 10.1115/1.2836459
Stochastic System Identification for Operational Modal Analysis: A Review, Journal of Dynamic Systems, Measurement, and Control, vol.123, issue.4, pp.659-667, 2001. ,
DOI : 10.1115/1.1410370
Modal Testing: Theory, Practice and Applications, 2000. ,
DOI : 10.1115/1.3269294
Modal Analysis Theory and Testing, 1995. ,
Applied System Identification, 1994. ,
REFERENCE-BASED STOCHASTIC SUBSPACE IDENTIFICATION FOR OUTPUT-ONLY MODAL ANALYSIS, Mechanical Systems and Signal Processing, pp.855-878, 1999. ,
DOI : 10.1006/mssp.1999.1249
Subspace-based methods for the identification of linear time-invariant systems, Automatica, vol.31, issue.12, pp.1835-1853, 1995. ,
DOI : 10.1016/0005-1098(95)00107-5
Sensor array processing based on subspace fitting, IEEE Transactions on Signal Processing, vol.39, issue.5, pp.1110-1121, 1991. ,
DOI : 10.1109/78.80966
Analysis of state space system identification methods based on instrumental variables and subspace fitting, Automatica, vol.33, issue.9, pp.1603-1616, 1997. ,
DOI : 10.1016/S0005-1098(97)00097-6
Analysis of subspace fitting and ML techniques for parameter estimation from sensor array data, IEEE Transactions on Signal Processing, vol.40, issue.3, pp.590-600, 1992. ,
DOI : 10.1109/78.120802
In-variance of subspace based estimators, IEEE Transactions on Signal Processing, vol.48, issue.9, pp.2495-2505, 2000. ,
DOI : 10.1109/78.863052
Introduction to Spectral Analysis, 1997. ,
Stochastic theory of minimal realization, IEEE Transactions on Automatic Control, vol.19, issue.6, pp.667-674, 1974. ,
DOI : 10.1109/TAC.1974.1100707
Merging sensor data from multiple measurement set-ups for nonstationary subspace-based modal analysis, pp.719-741, 2002. ,
Markovian Representation of Stochastic Processes by Canonical Variables, SIAM Journal on Control, vol.13, issue.1, pp.162-173, 1975. ,
DOI : 10.1137/0313010
Subspace-based fault detection algorithms for vibration monitoring, Automatica, vol.36, issue.1, pp.101-109, 2000. ,
DOI : 10.1016/S0005-1098(99)00093-X
Estimating Functions, 1991. ,
Quasi-Likelihood and Its Application, Series in Statistics, 1997. ,
The Theory and Application of Statistical Inference Functions, Lecture Notes in Statistics, vol.44, 1988. ,
Input/output versus output-only data processing for structural identification???Application to in-flight data analysis, Journal of Sound and Vibration, vol.295, issue.3-5, pp.531-552, 2006. ,
DOI : 10.1016/j.jsv.2006.01.039
Single sample modal identification of a nonstationary stochastic process, IEEE Transactions on Automatic Control, vol.30, issue.1, pp.66-74, 1985. ,
DOI : 10.1109/TAC.1985.1103787
Nonstationary Consistency of Subspace Methods, IEEE Transactions on Automatic Control, vol.52, issue.6, 2005. ,
DOI : 10.1109/TAC.2007.898970
Nonstationary Consistency of Subspace Methods, Proceedings of the 44th IEEE Conference on Decision and Control and European Control Conference (CDC-ECC '05), pp.7096-7101, 2005. ,
Blind subspace-based eigenstructure identification under nonstationary excitation using moving sensors, IEEE Transactions on Signal Processing, vol.50, issue.1, pp.41-48, 2002. ,
DOI : 10.1109/78.972480
URL : https://hal.archives-ouvertes.fr/inria-00072616
Aerodynamic Modeling and System Identification from Flight Data-Recent Applications at DLR, Journal of Aircraft, vol.41, issue.4, pp.681-691, 2004. ,
DOI : 10.2514/1.3165
Frequency-domain subspace identification using FRF data from arbitrary signals, Journal of Sound and Vibration, vol.290, issue.3-5, pp.3-5, 2006. ,
DOI : 10.1016/j.jsv.2005.04.021
Subspace-based multivariable system identification from frequency response data, IEEE Transactions on Automatic Control, vol.41, issue.7, pp.960-979, 1996. ,
DOI : 10.1109/9.508900
A multi-input modal parameter estimation algorithm for mini-computers, SAE Transaction, vol.91, issue.1, pp.815-821, 1982. ,
DIAGNOSING MECHANICAL CHANGES IN VIBRATING SYSTEMS, Proceedings of the 1st Symposium on Fault Detection, Supervision and Safety for Technical Processes (SAFEPROCESS '91), pp.159-164, 1991. ,
DOI : 10.1016/B978-0-08-041275-7.50023-5
The problem of diagnosis with respect to physical parameters for changes in structures, Research Report, vol.295, 1986. ,
URL : https://hal.archives-ouvertes.fr/inria-00438147
Diagnosing mechanical changes in vibrating systems Statistical modelbased damage detection and localization: subspace-based residuals and damage-to-noise sensitivity ratios, Research Report IRISA Journal of Sound and Vibration, vol.436, issue.275, pp.3-5, 1988. ,
Neyman-Le Cam tests based on estimating functions, Proceedings of the Berkeley Conference in, pp.811-825, 1985. ,
On Large-Sample Estimation and Testing in Parametric Models, International Statistical Review / Revue Internationale de Statistique, vol.58, issue.1, pp.77-97, 1990. ,
DOI : 10.2307/1403475
On-board Component Fault Detection and Isolation Using the Statistical Local Approach, Automatica, vol.34, issue.11, pp.1391-1415, 1998. ,
DOI : 10.1016/S0005-1098(98)00086-7
URL : https://hal.archives-ouvertes.fr/inria-00073437
Detection of Abrupt Changes?Theory and Applications, Information and System Sciences Series, 1993. ,
Fast In-Flight Detection of Flutter Onset: A Statistical Approach, Journal of Guidance, Control, and Dynamics, vol.28, issue.3, pp.431-438, 2005. ,
DOI : 10.2514/1.6184
URL : https://hal.archives-ouvertes.fr/inria-00071596
The asymptotic local approach to change detection and model validation, IEEE Transactions on Automatic Control, vol.32, issue.7, pp.583-592, 1987. ,
DOI : 10.1109/TAC.1987.1104683
URL : https://hal.archives-ouvertes.fr/inria-00075990
On the relationship between identfication and local tests, Research Report, vol.1104, 1104. ,
Early warning of slight changes in systems, Automatica, vol.30, issue.1, pp.95-113, 1994. ,
DOI : 10.1016/0005-1098(94)90231-3
URL : https://hal.archives-ouvertes.fr/inria-00076990
Advanced numerical computation of X 2 -tests for fault detection and isolation, Proceedings of the 5th Symposium on Fault Detection, Supervision and Safety for Technical Processes (SAFEPROCESS '03), pp.211-216, 2003. ,
Detecting changes in the ar parameters of a nonstationary arma process, Stochastics, vol.41, issue.1-2, pp.137-155, 1986. ,
DOI : 10.1016/0005-1098(76)90041-8
Detection and diagnosis of changes in the eigenstructure of nonstationary multivariable systems, Automatica, vol.23, issue.4, pp.479-489, 1987. ,
DOI : 10.1016/0005-1098(87)90077-X
URL : https://hal.archives-ouvertes.fr/inria-00076077
STOCHASTIC SUBSPACE-BASED STRUCTURAL IDENTIFICATION AND DAMAGE DETECTION ???APPLICATION TO THE STEEL-QUAKE BENCHMARK, Mechanical Systems and Signal Processing, vol.17, issue.1, pp.91-101, 2003. ,
DOI : 10.1006/mssp.2002.1544
An invariance property of some subspace-based detection algorithms, IEEE Transactions on Signal Processing, vol.47, issue.12, pp.3398-3400, 1999. ,
DOI : 10.1109/78.806083
Optimum robust detection of changes in the AR part of a multivariable ARMA process, IEEE Transactions on Automatic Control, vol.32, issue.12, pp.1116-1120, 1987. ,
DOI : 10.1109/TAC.1987.1104500
Diffusion approximation for a pseudo-likelihood test process with application to detection of change in a stochastic system, Stochastics An International Journal of Probability and Stochastic Processes, vol.32, issue.1, pp.1-25, 1990. ,
DOI : 10.1080/17442509008833651
Handling uncertainties in identification and model validation: a statistical approach, Proceedings of the 24th International Modal Analysis Conference (IMAC '06), SEM, 2006. ,
Model validation by using a damage detection test, Proceedings of the 24th International Modal Analysis Conference (IMAC '06), SEM, 2006. ,
On the achievable accuracy of structural system parameter estimates, Journal of Sound and Vibration, vol.34, issue.1, pp.63-79, 1974. ,
DOI : 10.1016/S0022-460X(74)80355-X
Multiple CUSUM tests for flutter monitoring, Proceedings of the 14th Symposium on System Identfication (SYSID '06), pp.624-629, 2006. ,
Recursive output-only subspace identification for in-flight flutter monitoring, Proceedings of the 22nd International Modal Analysis ConferenceSEM, 2004. ,
Online monitoring of slow to fast evolving aeronautic structures, Proceedings of the International Conference on Noise and Vibration Engineering, pp.1033-1047, 2004. ,
In situ damage monitoring in vibration mechanics: diagnostics and predictive maintenance, Mechanical Systems and Signal Processing, vol.7, issue.5, pp.401-423, 1993. ,
DOI : 10.1006/mssp.1993.1023
Output-Only Subspace-Based Damage Detection - Application to a Reticular Structure, Structural Health Monitoring, vol.2, issue.2, pp.161-168, 2003. ,
DOI : 10.1177/1475921703002002008
On-line monitoring of bradford stadium, Proceedings of the 23rd International Modal Analysis Conference (IMAC '05),SEM, 2005. ,
On-line monitoring of the crowd influence on manchester stadium, Proceedings of the 24th International Modal Analysis Conference (IMAC '06),S E M, 2006. ,
STOCHASTIC SUBSPACE-BASED STRUCTURAL IDENTIFICATION AND DAMAGE DETECTION AND LOCALISATION???APPLICATION TO THE Z24 BRIDGE BENCHMARK, Mechanical Systems and Signal Processing, vol.17, issue.1, pp.143-151, 2003. ,
DOI : 10.1006/mssp.2002.1552
APPLICATION OF A SUBSPACE-BASED FAULT DETECTION METHOD TO INDUSTRIAL STRUCTURES, Mechanical Systems and Signal Processing, vol.13, issue.6, pp.823-838, 1999. ,
DOI : 10.1006/mssp.1999.1247
Online vibrationbased crack detection during fatigue testing, Key Engineering Materials, vol.245, issue.2, pp.571-578, 2003. ,
DOI : 10.4028/www.scientific.net/kem.245-246.571
Subspace-based modal identification and monitoring of large structures, a Scilab toolbox, Proceedings of the 13th Symposium on System identification (SYSID '03), pp.1405-1410, 2003. ,
Overview of recent flight flutter testing research at NASA Dryden Flight flutter testing of transport aircraft: in-flight modal analysis, Proceedings of the 21st International Modal Analysis Conference (IMAC '03), SEM, 1997. ,
Flight Testing with the Flutterometer, Journal of Aircraft, vol.40, issue.3, pp.574-579, 2003. ,
DOI : 10.2514/2.3132
Vibration-based damage detection in civil engineering: excitation sources and temperature effects, Smart Materials and Structures, vol.10, issue.3, pp.518-527, 2001. ,
DOI : 10.1088/0964-1726/10/3/314
Information criteria for residual generation and fault detection and isolation, Automatica, vol.33, issue.5, pp.783-803, 1997. ,
DOI : 10.1016/S0005-1098(97)00004-6
URL : https://hal.archives-ouvertes.fr/inria-00073800
Fault isolation for diagnosis: Nuisance rejection and multiple hypotheses testing, Annual Reviews in Control, vol.26, issue.2, pp.189-202, 2002. ,
DOI : 10.1016/S1367-5788(02)00029-9
URL : https://hal.archives-ouvertes.fr/inria-00072150
Handling nuisance parameters in systems monitoring, Proceedings of the 44th IEEE Conference on Decision and Control, pp.3832-3837, 2005. ,
DOI : 10.1109/CDC.2005.1582759
