Self-synchronizing Huffman codes (Corresp.), IEEE Transactions on Information Theory, vol.30, issue.4, pp.687-693, 1984. ,
DOI : 10.1109/TIT.1984.1056931
Self-synchronizing variablelength codes for image transmission, Proceedings of IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP '92), pp.477-480, 1992. ,
Reversible variable length codes, IEEE Transactions on Communications, vol.43, issue.2/3/4, pp.158-162, 1995. ,
DOI : 10.1109/26.380026
Reversible variable length codes for efficient and robust image and video coding, Proceedings DCC '98 Data Compression Conference (Cat. No.98TB100225), pp.471-480, 1998. ,
DOI : 10.1109/DCC.1998.672209
Iterative source/channeldecoding using reversible variable length codes, Proceedings of Data Compression Conference (DCC '00), pp.93-102, 2000. ,
DOI : 10.1109/dcc.2000.838149
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.34.2390
Joint source-channel decoding of variable-length encoded sources, 1998 Information Theory Workshop (Cat. No.98EX131), pp.94-95, 1998. ,
DOI : 10.1109/ITW.1998.706451
Joint source/channel coding for variable length codes, Proceedings DCC '98 Data Compression Conference (Cat. No.98TB100225), pp.139-148, 1998. ,
DOI : 10.1109/DCC.1998.672140
K i n g s b u r y , " T h eE R E C :a ne r r o r resilient technique for coding variable-length blocks of data, IEEE Transactions on Image Processing, vol.5, issue.4, pp.565-574, 1996. ,
Errorresilient video coding techniques, IEEE Signal Processing Magazine, vol.17, issue.4, pp.61-82, 2000. ,
Rate-compatible punctured convolutional codes (RCPC codes) and their applications, IEEE Transactions on Communications, vol.36, issue.4, pp.389-400, 1988. ,
DOI : 10.1109/26.2763
Multilayered protection of embedded video bitstreams over binary symmetric and packet erasure channels, Journal of Visual Communication and Image Representation, vol.16, issue.3, pp.359-378, 2005. ,
DOI : 10.1016/j.jvcir.2004.08.001
A Method for the Construction of Minimum-Redundancy Codes, Proceedings of the IRE, vol.40, issue.9, pp.1098-1101, 1952. ,
DOI : 10.1109/JRPROC.1952.273898
Optimal Computer Search Trees and Variable-Length Alphabetical Codes, SIAM Journal on Applied Mathematics, vol.21, issue.4, pp.514-532, 1971. ,
DOI : 10.1137/0121057
High performance scalable image compression with EBCOT, IEEE Transactions on Image Processing, vol.9, issue.7, pp.1158-1170, 2000. ,
DOI : 10.1109/83.847830
Context-based adaptive binary arithmetic coding in the H.264/AVC video compression standard, IEEE Transactions on Circuits and Systems for Video Technology, pp.620-636, 2003. ,
DOI : 10.1109/TCSVT.2003.815173
Synchronization recovery of variable-length codes, IEEE Transactions on Information Theory, vol.48, issue.1, pp.219-227, 2002. ,
DOI : 10.1109/18.971750
Optimal decoding of linear codes for minimizing symbol error rate (Corresp.), IEEE Transactions on Information Theory, vol.20, issue.2, pp.284-287, 1974. ,
DOI : 10.1109/TIT.1974.1055186
Turbo-FEC/VLC-decoding and its application to text compression, Proceedings of the 34th Conference on Information Sciences and systems (CISS '00), p.pp ,
Joint source-channel turbo decoding of entropy-coded sources, IEEE Journal on Selected Areas in Communications, vol.19, issue.9, pp.1680-1696, 2001. ,
DOI : 10.1109/49.947033
Joint source-channel coding with variable length codes, Proceedings of IEEE International Symposium on Information Theory, p.419, 1997. ,
DOI : 10.1109/ISIT.1997.613356
Pseudo-Gray coding, IEEE Transactions on Communications, vol.38, issue.12, pp.2147-2158, 1990. ,
DOI : 10.1109/26.64657
A study of vector quantization for noisy channels, IEEE Transactions on Information Theory, vol.36, issue.4, pp.799-809, 1990. ,
DOI : 10.1109/18.53739
Binary codes capable of correcting deletions , insertions and reversals, Soviet Physics Doklady, vol.10, issue.8, pp.707-710, 1966. ,
Source code: C++ implementation of the for proposed algorithms ,
