Source and Channel Adaptive Rate Control for Multicast Layered Video Transmission Based on a Clustering Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue EURASIP Journal on Advances in Signal Processing Année : 2004
This paper introduces source-channel adaptive rate control (SARC), a new congestion control algorithm for layered video transmission in large multicast groups. In order to solve the well-known feedback implosion problem in large multicast groups, we first present a mechanism for filtering RTCP receiver reports sent from receivers to the whole session. The proposed filtering mechanism provides a classification of receivers according to a predefined similarity measure. An end-to-end source and FEC rate control based on this distributed feedback aggregation mechanism coupled with a video layered coding system is then described. The number of layers, their rate, and their levels of protection are adapted dynamically to aggregated feedbacks. The algorithms have been validated with the NS2 network simulator.
1687-6180-2004-396234.pdf (754.79 Ko) Télécharger le fichier
1687-6180-2004-396234.xml (3.52 Ko) Télécharger le fichier
Format : Autre
hal-00784486 , version 1 (04-02-2013)
  • HAL Id : hal-00784486 , version 1
Jérôme Viéron, Thierry Turletti, Kavé Salamatian, Christine Guillemot. Source and Channel Adaptive Rate Control for Multicast Layered Video Transmission Based on a Clustering Algorithm. EURASIP Journal on Advances in Signal Processing, 2004, 2004 (2), pp.396234. ⟨hal-00784486⟩
298 Consultations
153 Téléchargements
