Robin based semi-implicit coupling in fluidstructure interaction: Stability analysis and numerics, SIAM J. Sci. Comput, issue.6, pp.314041-4065, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00361284
Fluid???structure partitioned procedures based on Robin transmission conditions, Journal of Computational Physics, vol.227, issue.14, pp.7027-7051, 2008. ,
DOI : 10.1016/j.jcp.2008.04.006
Isogeometric fluid-structure interaction: theory, algorithms, and computations, Computational Mechanics, vol.196, issue.2, pp.3-37, 2008. ,
DOI : 10.1007/s00466-008-0315-x
Models and Finite Elements for Thin-Walled Structures, chapter 3, 2004. ,
NUMERICAL STABILITY OF THE FINITE ELEMENT IMMERSED BOUNDARY METHOD, Mathematical Models and Methods in Applied Sciences, vol.17, issue.10, pp.1479-1505, 2007. ,
DOI : 10.1142/S0218202507002352
On the Stabilization of Finite Element Approximations of the Stokes Equations, Notes Numer. Fluid Mech, vol.10, pp.11-19, 1984. ,
DOI : 10.1007/978-3-663-14169-3_2
Fluid???structure interaction in blood flow capturing non-zero longitudinal structure displacement, Journal of Computational Physics, vol.235, pp.515-541, 2013. ,
DOI : 10.1016/j.jcp.2012.08.033
Stabilized explicit coupling for fluid???structure interaction using Nitsche's method, Comptes Rendus Mathematique, vol.345, issue.8, pp.345467-472, 2007. ,
DOI : 10.1016/j.crma.2007.09.010
Galerkin Finite Element Methods with Symmetric Pressure Stabilization for the Transient Stokes Equations: Stability and Convergence Analysis, SIAM Journal on Numerical Analysis, vol.47, issue.1, pp.409-439, 2008. ,
DOI : 10.1137/070707403
URL : https://hal.archives-ouvertes.fr/inria-00178359
Stabilization of explicit coupling in fluid???structure interaction involving fluid incompressibility, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.5-8, pp.5-8766, 2009. ,
DOI : 10.1016/j.cma.2008.10.012
URL : https://hal.archives-ouvertes.fr/inria-00247409
Modeling Viscoelastic Behavior of Arterial Walls and Their Interaction with Pulsatile Blood Flow, SIAM Journal on Applied Mathematics, vol.67, issue.1, pp.164-193, 2006. ,
DOI : 10.1137/060651562
Added-mass effect in the design of partitioned algorithms for fluid???structure problems, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.42-44, pp.42-444506, 2005. ,
DOI : 10.1016/j.cma.2004.12.005
URL : https://hal.archives-ouvertes.fr/hal-00695954
The Finite Element Analysis of Shells -Fundamentals, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00839738
MODELING OF THE INCLUSION OF A REINFORCING SHEET WITHIN A 3D MEDIUM, Mathematical Models and Methods in Applied Sciences, vol.13, issue.04, pp.573-595, 2003. ,
DOI : 10.1142/S0218202503002635
URL : https://hal.archives-ouvertes.fr/hal-00839241
Parallel Algorithms for Fluid-Structure Interaction Problems in Haemodynamics, SIAM Journal on Scientific Computing, vol.33, issue.4, pp.1598-1622, 2011. ,
DOI : 10.1137/090772836
Fluid???structure algorithms based on Steklov???Poincar?? operators, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.41-43, pp.41-435797, 2006. ,
DOI : 10.1016/j.cma.2005.09.029
A computational framework for fluid???rigid body interaction: Finite element formulation and applications, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.13-16, pp.13-161633, 2006. ,
DOI : 10.1016/j.cma.2005.05.033
Effect of baffles on a partially filled cubic tank: Numerical simulation and experimental validation, Computers & Structures, vol.87, issue.3-4, pp.3-4198, 2009. ,
DOI : 10.1016/j.compstruc.2008.10.008
Coupling schemes for incompressible fluid-structure interaction: implicit, semi-implicit and explicit Incremental displacement-correction schemes for the explicit coupling of a thin structure with an incompressible fluid, S eMA J. C. R. Math. Acad. Sci. Paris, vol.349, issue.5578, pp.59-108473, 2011. ,
Incremental displacement-correction schemes for incompressible fluid-structure interaction, Numerische Mathematik, vol.17, issue.6, pp.21-65, 2013. ,
DOI : 10.1007/s00211-012-0481-9
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, International Journal for Numerical Methods in Engineering, vol.9, issue.4, pp.794-821, 2007. ,
DOI : 10.1002/nme.1792
A Newton method using exact jacobians for solving fluid???structure coupling, Computers & Structures, vol.83, issue.2-3, pp.127-142, 2005. ,
DOI : 10.1016/j.compstruc.2004.04.021
Displacement-velocity correction schemes for incompressible fluid???structure interaction, Comptes Rendus Mathematique, vol.349, issue.17-18, pp.17-181011, 2011. ,
DOI : 10.1016/j.crma.2011.08.004
Generalized Robin-Neumann explicit coupling schemes for incompressible fluid-structure interaction. Part I: Stability analysis and numerics, 2013. ,
On the coupling of 3D and 1D Navier???Stokes equations for flow problems in compliant vessels, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.6-7, pp.6-7561, 2001. ,
DOI : 10.1016/S0045-7825(01)00302-4
URL : https://hal.archives-ouvertes.fr/hal-00691928
of Modeling, Simulation and Applications, Cardiovascular Mathematics. Modeling and simulation of the circulatory system, 2009. ,
Artificial added mass instabilities in sequential staggered coupling of nonlinear structures and incompressible viscous flows, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.7, pp.1278-1293, 2007. ,
DOI : 10.1016/j.cma.2006.09.002
Parallel multilevel solution of nonlinear shell structures, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.21-24, pp.21-242513, 2005. ,
DOI : 10.1016/j.cma.2004.07.043
Truly monolithic algebraic multigrid for fluid-structure interaction, International Journal for Numerical Methods in Engineering, vol.33, issue.2, pp.987-1016, 2011. ,
DOI : 10.1002/nme.3001
A Quasi-Newton Algorithm Based on a Reduced Model for Fluid-Structure Interaction Problems in Blood Flows, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.4, pp.631-648, 2003. ,
DOI : 10.1051/m2an:2003049
URL : https://hal.archives-ouvertes.fr/hal-00694625
Stable loosely-coupled-type algorithm for fluid???structure interaction in blood flow, Journal of Computational Physics, vol.228, issue.18, pp.6916-6937, 2009. ,
DOI : 10.1016/j.jcp.2009.06.007
Nitsche's method for interface problems in computa-tional mechanics, GAMM-Mitteilungen, vol.15, issue.2, pp.183-206, 2005. ,
DOI : 10.1002/gamm.201490018
Fluid-Structure Interaction in Internal Physiological Flows, Annual Review of Fluid Mechanics, vol.43, issue.1, pp.141-162, 2011. ,
DOI : 10.1146/annurev-fluid-122109-160703
Finite-Element Approximation of the Nonstationary Navier???Stokes Problem. Part IV: Error Analysis for Second-Order Time Discretization, SIAM Journal on Numerical Analysis, vol.27, issue.2, pp.353-384, 1990. ,
DOI : 10.1137/0727022
The finite element method, 1987. ,
Mechanical Models of Artery Walls, Archives of Computational Methods in Engineering, vol.287, issue.3, pp.1-36, 2008. ,
DOI : 10.1007/s11831-007-9015-5
Fixed-point fluid???structure interaction solvers with dynamic relaxation, Computational Mechanics, vol.35, issue.6???8, pp.61-72, 2008. ,
DOI : 10.1007/s00466-008-0255-5
A Solution for the Incompressibility Dilemma in Partitioned Fluid???Structure Interaction with Pure Dirichlet Fluid Domains, Computational Mechanics, vol.195, issue.11, pp.417-429, 2006. ,
DOI : 10.1007/s00466-006-0066-5
Fluid structure interaction with large structural displacements, Comput. Meth. Appl. Mech. Engrg, vol.190, pp.3039-3067, 2001. ,
Numerical Simulation of Sailing Boats: Dynamics, FSI, and Shape Optimization, Variational Analysis and Aerospace Engineering: Mathematical Challenges for Aerospace Design, pp.339-377, 2012. ,
DOI : 10.1007/978-1-4614-2435-2_15
Kinematic splitting algorithm for fluid???structure interaction in hemodynamics, Computer Methods in Applied Mechanics and Engineering, vol.265, issue.1, pp.83-106, 2013. ,
DOI : 10.1016/j.cma.2013.05.025
External tissue support and fluid-structure simulation in blood flows, Biomech. Model. Mechanobiol, vol.11, pp.1-18, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00701801
An efficient preconditioner for monolithically-coupled large-displacement fluid???structure interaction problems with pseudo-solid mesh updates, Journal of Computational Physics, vol.231, issue.21, pp.7315-7334, 2012. ,
DOI : 10.1016/j.jcp.2012.07.001
??ber ein Variationsprinzip zur L??sung von Dirichlet-Problemen bei Verwendung von Teilr??umen, die keinen Randbedingungen unterworfen sind, Abhandlungen aus dem Mathematischen Seminar der Universit??t Hamburg, vol.12, issue.1, pp.9-15, 1971. ,
DOI : 10.1007/BF02995904
An Effective Fluid-Structure Interaction Formulation for Vascular Dynamics by Generalized Robin Conditions, SIAM Journal on Scientific Computing, vol.30, issue.2, pp.731-763, 2008. ,
DOI : 10.1137/060678439
Partitioned Algorithms for Fluid-Structure Interaction Problems in Haemodynamics, Milan Journal of Mathematics, vol.4, issue.4, pp.443-467, 2012. ,
DOI : 10.1007/s00032-012-0194-7
Fluid-structure interactions: cross-flowinduced instabilities, 2011. ,
DOI : 10.1017/CBO9780511760792
The immersed boundary method, Acta Numer, vol.11, pp.479-517, 2002. ,
A SEMI-IMPLICIT APPROACH FOR FLUID-STRUCTURE INTERACTION BASED ON AN ALGEBRAIC FRACTIONAL STEP METHOD, Mathematical Models and Methods in Applied Sciences, vol.17, issue.06, pp.957-98319, 2006. ,
DOI : 10.1142/S0218202507002170
Computational Methods for Parachute Fluid???Structure Interactions, Archives of Computational Methods in Engineering, vol.20, issue.1, pp.125-169, 2012. ,
DOI : 10.1007/s11831-012-9070-4
Stability and Instability in the Computation of Flows with Moving Immersed Boundaries: A Comparison of Three Methods, SIAM Journal on Scientific and Statistical Computing, vol.13, issue.6, pp.1361-1376, 1992. ,
DOI : 10.1137/0913077
Viscoelastic models for passive arterial wall dynamics, Adv. Appl. Math. Mech, vol.1, issue.2, pp.151-165, 2009. ,
