Distributed Average Consensus using Probabilistic Quantization, 2007 IEEE/SP 14th Workshop on Statistical Signal Processing, pp.640-644, 2007. ,
DOI : 10.1109/SSP.2007.4301337
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.130.5514
An efficient quantization algorithm for solving average-consensus problems, Proceedings of the European Control Conference, 2009. ,
Simultaneous design of measurement and control strategies for stochastic systems with feedback, Automatica, vol.25, issue.5, pp.25-679, 1989. ,
DOI : 10.1016/0005-1098(89)90024-1
Parallel and Distributed Computation: Numerical Methods, Athena Scientific, 1997. ,
Randomized gossip algorithms, IEEE Transactions on Information Theory, vol.52, issue.6, pp.2508-2530, 2006. ,
DOI : 10.1109/TIT.2006.874516
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.133.8625
Average consensus on networks with transmission noise or quantization, ECC '07, pp.1852-1857, 2007. ,
Gossip consensus algorithms via quantized communication, Automatica, vol.46, issue.1, pp.46-70, 2010. ,
DOI : 10.1016/j.automatica.2009.10.032
URL : http://arxiv.org/abs/0907.0748
LQG optimality and separation principle for general discrete time partially observed stochastic systems over finite capacity communication channels, Automatica, vol.44, issue.12, pp.44-3181, 2008. ,
DOI : 10.1016/j.automatica.2008.05.021
Dynamic load balancing for distributed memory multiprocessors, Journal of Parallel and Distributed Computing, vol.7, issue.2, pp.279-301, 1989. ,
DOI : 10.1016/0743-7315(89)90021-X
Efficient schemes for nearest neighbor load balancing, Parallel Computing, vol.25, issue.7, pp.789-812, 1999. ,
DOI : 10.1016/S0167-8191(99)00018-6
Geographic Gossip: Efficient Averaging for Sensor Networks, IEEE Transactions on Signal Processing, vol.56, issue.3, pp.1205-1216, 2008. ,
DOI : 10.1109/TSP.2007.908946
Robust coding for a class of sources: applications in control and reliable communication over limited capacity channels, Systems and Control Letters, pp.3181-3188, 2008. ,
Stability and reliable data recosntruction of uncertain dynamic systems over finite capacity channels, Automatica, pp.46-889, 2010. ,
Randomized consensus algorithms over large scale networks, IEEE Journal on Selected Areas in Communications, vol.26, issue.4, pp.634-649, 2008. ,
DOI : 10.1109/JSAC.2008.080506
Average consensus by gossip algorithms with quantized communication, 2008 47th IEEE Conference on Decision and Control, pp.4831-4836, 2008. ,
DOI : 10.1109/CDC.2008.4738921
Dwell-time adaptive Delta modulation signal coding for networked control systems, 2011. ,
Directed diffusion, Proceedings of the 6th annual international conference on Mobile computing and networking , MobiCom '00, pp.56-67, 2000. ,
DOI : 10.1145/345910.345920
Coordination of groups of mobile autonomous agents using nearest neighbor rules, IEEE Trans. Automat . Control, pp.48-988, 2003. ,
Dwell -time adaptive delta modulation signal coding for networked controlled systems, 2010. ,
Gossip-based computation of aggregate information, 44th Annual IEEE Symposium on Foundations of Computer Science, 2003. Proceedings., pp.1-10 ,
DOI : 10.1109/SFCS.2003.1238221
On quantized consensus by means of gossip algorithm - Part I: Convergence proof, 2009 American Control Conference, 2009. ,
DOI : 10.1109/ACC.2009.5160485
Input-to-State Stabilization of Linear Systems With Quantized State Measurements, IEEE Transactions on Automatic Control, vol.52, issue.5, pp.767-781, 2007. ,
DOI : 10.1109/TAC.2007.895850
Stability of multiagent systems with time-dependent communication links, IEEE Transactions on Automatic Control, vol.50, issue.2, pp.169-182, 2005. ,
DOI : 10.1109/TAC.2004.841888
First and second order diffusive methods for rapid, coarse, distributed load balancing, Theory of computing systems, pp.31-331, 1998. ,
Mean square stabilisability of stochastic linear systems with data rate constraints Stabilizability of stochastic linear systems with finite feedback data rates, Proc. IEEE CDC, pp.43-413, 2002. ,
Feedback control under data rate constrints: An overview, Proceeding of the IEEE, pp.108-136, 2007. ,
Consensus Problems in Networks of Agents With Switching Topology and Time-Delays, IEEE Transactions on Automatic Control, vol.49, issue.9, pp.49-1520, 2004. ,
DOI : 10.1109/TAC.2004.834113
Random Geometric Graphs, Oxford Studies in Probability, 2003. ,
Consensus seeking in multiagent systems under dynamically changing interaction topologies, IEEE Trans. Automat . Control, pp.50-655, 2005. ,
Input-to-state stabilization with minimum number of quantization regions, 2007 46th IEEE Conference on Decision and Control, 2007. ,
DOI : 10.1109/CDC.2007.4434339
A Necessary and Sufficient Condition for Consensus Over Random Networks, IEEE Transactions on Automatic Control, vol.53, issue.3, pp.791-795, 2008. ,
DOI : 10.1109/TAC.2008.917743
Control Over Noisy Channels, IEEE Transactions on Automatic Control, vol.49, issue.7, pp.1196-1201, 2004. ,
DOI : 10.1109/TAC.2004.831102
Problems in decentralized decision making and computation, Ph.D. dissertation, Dep. Elec. Eng. Comput. Sci., Mass. Inst. Technol, 1984. ,
Decentralized estimation in an inhomogeneous sensing environment, IEEE Trans. Inf. Theory, pp.51-3564, 2005. ,
Computing aggregates for monitoring wireless sensor networks, Proceedings of the First IEEE International Workshop on Sensor Network Protocols and Applications, 2003., pp.139-148 ,
DOI : 10.1109/SNPA.2003.1203364
