Rate sufficient conditions for closed-loop control over AWGN relay channels, IEEE ICCA 2010, 2010. ,
DOI : 10.1109/ICCA.2010.5524411
Feedback strategies for white Gaussian interference networks, IEEE Transactions on Information Theory, vol.48, issue.6, pp.481423-1438, 2002. ,
DOI : 10.1109/TIT.2002.1003831
Stochastic Stabilization of Noisy Linear Systems With Fixed-Rate Limited Feedback, IEEE Transactions on Automatic Control, vol.55, issue.12, p.99, 2010. ,
DOI : 10.1109/TAC.2010.2079510
The capacity of the Gaussian interference channel under strong interference (Corresp.), IEEE Transactions on Information Theory, vol.27, issue.6, pp.786-788, 1981. ,
DOI : 10.1109/TIT.1981.1056416
When Feedback doubles the prelog in AWGN networks, IEEE Trans. Inform. Theory ,
Interference channels, IEEE Transactions on Information Theory, vol.24, issue.1, pp.60-70, 1978. ,
DOI : 10.1109/TIT.1978.1055812
On Optimal Policies for Control and Estimation Over a Gaussian Relay Channel, IEEE CDC, 2011. ,
Sufficient conditions for closed-loop control over a Gaussian relay channel, Proceedings of the 2011 American Control Conference, 2011. ,
DOI : 10.1109/ACC.2011.5991326
Closed-loop Control over Half-duplex AWGN Relay Channels, Reglermöte, 2010. ,
DOI : 10.1109/icca.2010.5524411
Rate sufficient conditions for closed-loop control over AWGN relay channels, IEEE ICCA 2010, pp.602-607, 2010. ,
Sufficient conditions for closed-loop control over multiple-access and broadcast channels, 49th IEEE Conference on Decision and Control (CDC), 2010. ,
DOI : 10.1109/CDC.2010.5717279
Distributed Sensing and Control over Communication Channels and a Counterexample, Allerton Conference on Communication, Control, and Computing, pp.260-267, 2007. ,
Optimization and convergence of observation channels in stochastic control, SIAM J. Control Optim ,
Achievable Rates for Stability of LTI Systems over Noisy Forward and Feedback Channels, Proc. Conference on Information Sciences and Systems, 2005. ,
Control Over Noisy Forward and Reverse Channels, IEEE Transactions on Automatic Control, vol.56, issue.5, p.56, 2011. ,
DOI : 10.1109/TAC.2010.2081730
On optimal causal coding of partially observed Markov sources under classical and non-classical information structures, 2010 IEEE International Symposium on Information Theory, pp.81-85, 2010. ,
DOI : 10.1109/ISIT.2010.5513287
Functional properties of MMSE, 2010 IEEE International Symposium on Information Theory, pp.1453-1457, 2010. ,
DOI : 10.1109/ISIT.2010.5513606
A Counterexample in Stochastic Optimum Control, SIAM Journal on Control, vol.6, issue.1, pp.131-147, 1968. ,
DOI : 10.1137/0306011
Optimal causal coding - decoding problems, IEEE Transactions on Information Theory, vol.29, issue.6, pp.29814-820, 1983. ,
DOI : 10.1109/TIT.1983.1056760
Team Decision Problems, The Annals of Mathematical Statistics, vol.33, issue.3, pp.857-881, 1962. ,
DOI : 10.1214/aoms/1177704455
The capacity of the white Gaussian multiple access channel with feedback, IEEE Transactions on Information Theory, vol.30, issue.4, pp.623-629, 1984. ,
DOI : 10.1109/TIT.1984.1056935
An achievable region and outer bound for the Gaussian broadcast channel with feedback (Corresp.), IEEE Transactions on Information Theory, vol.30, issue.4, pp.30667-671, 1984. ,
DOI : 10.1109/TIT.1984.1056923
Data Rate Theorem for Stabilization Over Time-Varying Feedback Channels, IEEE Transactions on Automatic Control, vol.54, issue.2, pp.54243-255, 2009. ,
DOI : 10.1109/TAC.2008.2010887
Comments on "Control over noisy channels" and relevant negative results, IEEE Transactions on Automatic Control, vol.50, issue.12, pp.2105-2110, 2005. ,
DOI : 10.1109/TAC.2005.860258
Finite horizon optimal memoryless control of a delay in Gaussian noise: A simple counterexample, 2008 47th IEEE Conference on Decision and Control, pp.1628-1635, 2008. ,
DOI : 10.1109/CDC.2008.4739088
Optimal memoryless control in Gaussian noise: A simple counterexample, Automatica, vol.47, issue.3, 2011. ,
DOI : 10.1016/j.automatica.2010.12.001
Sufficient conditions for stabilizability over Gaussian relay and cascade channels, 49th IEEE Conference on Decision and Control (CDC), pp.4765-4770, 2010. ,
DOI : 10.1109/CDC.2010.5717204
Optimal relay functionality for SNR maximization in memoryless relay networks, IEEE Journal on Selected Areas in Communications, vol.25, issue.2, pp.390-401, 2007. ,
DOI : 10.1109/JSAC.2007.070214
Cooperative Strategies and Capacity Theorems for Relay Networks, IEEE Transactions on Information Theory, vol.51, issue.9, pp.513037-3063, 2005. ,
DOI : 10.1109/TIT.2005.853304
Optimized low-delay source-channel-relay mappings, IEEE Transactions on Communications, vol.58, issue.5, pp.1397-1404, 2010. ,
DOI : 10.1109/TCOMM.2010.05.080595
Team decision theory and information structures, Proceedings of the IEEE, pp.644-654, 1980. ,
Statistical digital signal processing and modelling, 1996. ,
On the Capacity of Large Gaussian Relay Networks, IEEE Transactions on Information Theory, vol.51, issue.3, pp.765-779, 2005. ,
DOI : 10.1109/TIT.2004.842566
To code or not to code, 2000 IEEE International Symposium on Information Theory (Cat. No.00CH37060), 2000. ,
DOI : 10.1109/ISIT.2000.866534
Cut-set arguments for source-channel networks, International Symposium onInformation Theory, 2004. ISIT 2004. Proceedings., 2004. ,
DOI : 10.1109/ISIT.2004.1365069
Uncoded Transmission Is Exactly Optimal for a Simple Gaussian “Sensor” Network, IEEE Transactions on Information Theory, vol.54, issue.11, pp.5247-5251, 2008. ,
DOI : 10.1109/TIT.2008.929967
Source Transmission over Relay Channel with Correlated Relay Side Information, 2007 IEEE International Symposium on Information Theory, 2007. ,
DOI : 10.1109/ISIT.2007.4557292
Feedback Stabilization Over Signal-to-Noise Ratio Constrained Channels, IEEE Transactions on Automatic Control, vol.52, issue.8, pp.521391-1403, 2007. ,
DOI : 10.1109/TAC.2007.902739
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.323.8336
Stabilization and Disturbance Attenuation Over a Gaussian Communication Channel, IEEE Transactions on Automatic Control, vol.55, issue.3, pp.55-795, 2010. ,
DOI : 10.1109/TAC.2010.2040507
Optimum mean-square quantization of a noisy input, IEEE Trans. Inf. Theory, vol.11, pp.293-294, 1965. ,
When Bode Meets Shannon: Control-Oriented Feedback Communication Schemes, IEEE Transactions on Automatic Control, vol.49, issue.9, pp.1477-1488, 2004. ,
DOI : 10.1109/TAC.2004.834119
Information transmission with additional noise, IEEE Transactions on Information Theory, vol.8, issue.5, pp.293-304, 1962. ,
DOI : 10.1109/TIT.1962.1057738
Elements of information theory, 2006. ,
Rate-Distortion Theory, 1971. ,
DOI : 10.1002/0471219282.eot142
Solutions to a class of linear-quadratic- Gaussian LQG stochastic team problems with nonclassical information, Systems Control Letters, pp.125-130, 1987. ,
The design of joint source and channel trellis waveform coders, IEEE Transactions on Information Theory, vol.33, issue.6, pp.855-865, 1987. ,
DOI : 10.1109/TIT.1987.1057376
Optimization of Stochastic Systems -Topics in Discrete-Time Systems, 1967. ,
Distributed Average Consensus using Probabilistic Quantization, 2007 IEEE/SP 14th Workshop on Statistical Signal Processing, pp.640-644, 2007. ,
DOI : 10.1109/SSP.2007.4301337
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.130.5514
An efficient quantization algorithm for solving average-consensus problems, Proceedings of the European Control Conference, 2009. ,
Simultaneous design of measurement and control strategies for stochastic systems with feedback, Automatica, vol.25, issue.5, pp.25-679, 1989. ,
DOI : 10.1016/0005-1098(89)90024-1
Iterative Encoder-Controller Design for Feedback Control Over Noisy Channels, IEEE Transactions on Automatic Control, vol.56, issue.2, 2010. ,
DOI : 10.1109/TAC.2010.2051833
On the inherent intractability of certain coding problems (Corresp.), IEEE Transactions on Information Theory, vol.24, issue.3, pp.24-384, 1978. ,
DOI : 10.1109/TIT.1978.1055873
Parallel and Distributed Computation: Numerical Methods, Athena Scientific, 1997. ,
Modern graph theory, 1998. ,
DOI : 10.1007/978-1-4612-0619-4
some fundamental limits of unequal error protection, 2008 IEEE International Symposium on Information Theory, pp.55-5511, 2009. ,
DOI : 10.1109/ISIT.2008.4595385
Randomized gossip algorithms, IEEE Transactions on Information Theory, vol.52, issue.6, pp.2508-2530, 2006. ,
DOI : 10.1109/TIT.2006.874516
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.133.8625
Feedback Stabilization Over Signal-to-Noise Ratio Constrained Channels, IEEE Transactions on Automatic Control, vol.52, issue.8, pp.1391-1403, 2007. ,
Quantized feedback stabilization of linear systems, IEEE Transactions on Automatic Control, vol.45, issue.7, pp.1279-1289, 2000. ,
DOI : 10.1109/9.867021
On the Relay Channel With Receiver–Transmitter Feedback, IEEE Transactions on Information Theory, vol.55, issue.1, pp.275-291, 2009. ,
DOI : 10.1109/TIT.2008.2008144
A new lower bound for the a-mean error of parameter transmission over the white Gaussian channel, IEEE Transactions on Information Theory, vol.30, issue.1, pp.23-34, 1984. ,
DOI : 10.1109/TIT.1984.1056846
Average consensus over digital noisy networks, Proc. IFAC NecSys'09, pp.24-26 ,
Average consensus on networks with transmission noise or quantization, ECC '07, pp.1852-1857, 2007. ,
Gossip consensus algorithms via quantized communication, Automatica, vol.46, issue.1, pp.46-70, 2010. ,
DOI : 10.1016/j.automatica.2009.10.032
LQG optimality and separation principle for general discrete time partially observed stochastic systems over finite capacity communication channels, Automatica, vol.44, issue.12, pp.44-3181, 2008. ,
DOI : 10.1016/j.automatica.2008.05.021
Lower bounds on the estimation error in problems of distributed computation, invited paper, Proc. of ITA Workshop, pp.8-13, 2009. ,
Anytime Reliable Transmission of Real-Valued Information through Digital Noisy Channels, SIAM Journal on Control and Optimization, vol.48, issue.6, pp.3903-3924, 2010. ,
DOI : 10.1137/09074601X
Joint source-channel error exponent, Probl. Control Inf. Theory, vol.9, pp.315-328, 1980. ,
Dynamic load balancing for distributed memory multiprocessors, Journal of Parallel and Distributed Computing, vol.7, issue.2, pp.279-301, 1989. ,
DOI : 10.1016/0743-7315(89)90021-X
Efficient schemes for nearest neighbor load balancing, Parallel Computing, vol.25, issue.7, pp.789-812, 1999. ,
DOI : 10.1016/S0167-8191(99)00018-6
Geographic Gossip: Efficient Averaging for Sensor Networks, IEEE Transactions on Signal Processing, vol.56, issue.3, pp.1205-1216, 2008. ,
DOI : 10.1109/TSP.2007.908946
Randomized consensus algorithms over large scale networks, IEEE Journal on Selected Areas in Communications, vol.26, issue.4, pp.634-649, 2008. ,
DOI : 10.1109/JSAC.2008.080506
A study of vector quantization for noisy channels, IEEE Transactions on Information Theory, vol.36, issue.4, pp.36-799, 1990. ,
DOI : 10.1109/18.53739
Convolutional codes II. Maximum-likelihood decoding, Information and Control, vol.25, issue.3, pp.222-266, 1974. ,
DOI : 10.1016/S0019-9958(74)90870-5
Average consensus by gossip algorithms with quantized communication, 2008 47th IEEE Conference on Decision and Control, pp.4831-4836, 2008. ,
DOI : 10.1109/CDC.2008.4738921
The minimal signal-tonoise ratio rqeuired to stabilize over a noisy channel, Proc. ACC, 2006. ,
Linear quadratic gaussian control with quantized feedback, Proc. of the 2009 American Control conference, 2009. ,
Information Theory and Reliable Communication, 1968. ,
DOI : 10.1007/978-3-7091-2945-6
Vector quantization and signal compression, 1992. ,
DOI : 10.1007/978-1-4615-3626-0
Towards the control of linear systems with minimum bit?rate, 15th Int. Symp. Mathematical Theory of Networks and Systems (MTNS), 2002. ,
Directed diffusion, Proceedings of the 6th annual international conference on Mobile computing and networking , MobiCom '00, pp.56-67, 2000. ,
DOI : 10.1145/345910.345920
Coordination of groups of mobile autonomous agents using nearest neighbor rules, IEEE Trans. Automat . Control, pp.48-988, 2003. ,
Dwell -time adaptive delta modulation signal coding for networked controlled systems ,
Gossip-based computation of aggregate information, 44th Annual IEEE Symposium on Foundations of Computer Science, 2003. Proceedings., pp.1-10 ,
DOI : 10.1109/SFCS.2003.1238221
Cooperative Communications, Foundations and Trends?? in Networking, vol.1, issue.3-4, pp.271-425, 2006. ,
DOI : 10.1561/1300000004
On quantized consensus by means of gossip algorithm - Part I: Convergence proof, 2009 American Control Conference, 2009. ,
DOI : 10.1109/ACC.2009.5160485
On stabilization of linear systems with limited information, IEEE Transactions on Automatic Control, vol.48, issue.2, pp.304-307, 2003. ,
DOI : 10.1109/TAC.2002.808487
Input-to-State Stabilization of Linear Systems With Quantized State Measurements, IEEE Transactions on Automatic Control, vol.52, issue.5, pp.767-781, 2007. ,
DOI : 10.1109/TAC.2007.895850
On linear unequal error protection codes, IEEE Transactions on Information Theory, vol.13, issue.4, pp.600-607, 1967. ,
DOI : 10.1109/TIT.1967.1054054
Estimation and control over communication networks, 2009. ,
An Analogue of Shannon Information Theory for Detection and Stabilization via Noisy Discrete Communication Channels, SIAM Journal on Control and Optimization, vol.46, issue.4, pp.1323-1367, 2007. ,
DOI : 10.1137/040621697
The problem of LQG optimal control via a limited capacity communication channel, Systems and Control letters, pp.51-64, 2004. ,
Information theory, inference, and learning algorithms, 2003. ,
Feedback Stabilization Over a First Order Moving Average Gaussian Noise Channel, IEEE Transactions on Automatic Control, vol.54, issue.1, p.54, 2009. ,
DOI : 10.1109/TAC.2008.2007183
Stability of multiagent systems with time-dependent communication links, IEEE Transactions on Automatic Control, vol.50, issue.2, pp.169-182, 2005. ,
DOI : 10.1109/TAC.2004.841888
First and second order diffusive methods for rapid, coarse, distributed load balancing, Theory of computing systems, pp.31-331, 1998. ,
Mean square stabilisability of stochastic linear systems with data rate constraints, Proceedings of the 41st IEEE Conference on Decision and Control, 2002., 2002. ,
DOI : 10.1109/CDC.2002.1184753
Feedback control under data rate constrints: An overview, Proceeding of the IEEE, pp.108-136, 2007. ,
Consensus Problems in Networks of Agents With Switching Topology and Time-Delays, IEEE Transactions on Automatic Control, vol.49, issue.9, pp.49-1520, 2004. ,
DOI : 10.1109/TAC.2004.834113
Random Geometric Graphs, Oxford Studies in Probability, 2003. ,
Consensus seeking in multiagent systems under dynamically changing interaction topologies, IEEE Trans. Automat . Control, pp.50-655, 2005. ,
Modern Coding Theory, 2007. ,
DOI : 10.1017/CBO9780511791338
Why Do Block Length and Delay Behave Differently if Feedback Is Present?, IEEE Transactions on Information Theory, vol.54, issue.5, pp.1860-1886, 2008. ,
DOI : 10.1109/TIT.2008.920339
The necessity and sufficiency of anytime capacity for stabilization of a linear system over noisy communication links? Part I: Scalar systems, IEEE Trans. Inform. Theory, pp.52-3369, 2006. ,
A coding scheme for additive noise channels with feedback?i: No bandwidth constraint, IEEE Trans. Inform. Theory, vol.12, pp.172-182, 1966. ,
Input-to-state stabilization with minimum number of quantization regions, 2007 46th IEEE Conference on Decision and Control, 2007. ,
DOI : 10.1109/CDC.2007.4434339
Simple coding for achieving mean square stability over bit-rate limited channels, 2008 47th IEEE Conference on Decision and Control, 2008. ,
DOI : 10.1109/CDC.2008.4738963
Scalar Estimation and Control With Noisy Binary Observations, IEEE Transactions on Automatic Control, vol.49, issue.9, pp.49-1598, 2004. ,
DOI : 10.1109/TAC.2004.834103
A Necessary and Sufficient Condition for Consensus Over Random Networks, IEEE Transactions on Automatic Control, vol.53, issue.3, pp.791-795, 2008. ,
DOI : 10.1109/TAC.2008.917743
Control Over Noisy Channels, IEEE Transactions on Automatic Control, vol.49, issue.7, pp.1196-1201, 2004. ,
DOI : 10.1109/TAC.2004.831102
Problems in decentralized decision making and computation, Ph.D. dissertation, Dep. Elec. Eng. Comput. Sci., Mass. Inst. Technol, 1984. ,
Further results on optimal decoding of convolutional codes (Corresp.), IEEE Transactions on Information Theory, vol.15, issue.6, pp.732-734, 1969. ,
DOI : 10.1109/TIT.1969.1054375
Decentralized estimation in an inhomogeneous sensing environment, IEEE Trans. Inf. Theory, pp.51-3564, 2005. ,
Coding and Control over Discrete Noisy Forward and Feedback Channels, Proceedings of the 44th IEEE Conference on Decision and Control, 2005. ,
DOI : 10.1109/CDC.2005.1582541
A counterexample in distributed optimal sensing and control, IEEE Trans. Automat. Control, p.54, 2009. ,
Ratemaximizing mappings for memoryless relaying, Proc. IEEE ISIT, 2009. ,
Rate sufficient conditions for closed?loop control over half?duplex AWGN relay channels, 2010. ,
Computing aggregates for monitoring wireless sensor networks, Proceedings of the First IEEE International Workshop on Sensor Network Protocols and Applications, 2003., pp.139-148 ,
DOI : 10.1109/SNPA.2003.1203364
Using Anytime Algorithms in Intelligent Systems, AI Magazine, pp.73-83, 1996. ,
