Hypergraph Partitioning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2011
Bora Uçar
Cevdet Aykanat
  • Fonction : Auteur
  • PersonId : 882785
Hypergraphs are generalization of graphs where each edge (hyperedge) can connect more than two vertices. In simple terms, the hypergraph partitioning problem can be defined as the task of dividing the vertices of hypergraph into two or more roughly equal sized parts such that a cost function on the hyperedges connecting vertices in different parts is minimized.
hp-encyc.pdf (747.27 Ko) Télécharger le fichier
hal-00786552 , version 1 (09-11-2019)
  • HAL Id : hal-00786552 , version 1
Umit V. Catalyurek, Bora Uçar, Cevdet Aykanat. Hypergraph Partitioning. David A. Padua. Encyclopedia of Parallel Computing, Springer, pp.871--881, 2011. ⟨hal-00786552⟩
158 Consultations
281 Téléchargements
