Error Propagation in Variational Data Assimilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The approach of Data Assimilation via Optimal Control Methods leads to a dynamical system: the Optimality System in which all the available information is gathered. The propagation of uncertainties must be carried out not just from the model but from the O.S. I introduced a second adjoint from where the evaluation of the dynamics of uncertainties are studied.
Fichier non déposé
hal-00787278 , version 1 (11-02-2013)
  • HAL Id : hal-00787278 , version 1
François-Xavier Le Dimet, M.Yussuf Hussaini, David Furbish, Igor Gejadze, Victor P. Shutyaev. Error Propagation in Variational Data Assimilation. ECODYC 2010 - Exploring Complex Dynamics in High-Dimensional Chaotic Systems: From Weather Forecasting to Oceanic Flows, Jan 2010, Dresde, Germany. ⟨hal-00787278⟩
437 Consultations
0 Téléchargements
