A novel progressive spongiform encephalopathy in cattle, Vet Rec, vol.121, pp.419-420, 1987. ,
Bovine spongiform encephalopathy: epidemiological studies, Vet Rec, vol.123, pp.638-644, 1988. ,
, A new variant of Creutzfeldt-Jakob disease in the UK. Lancet, vol.347, pp.921-925, 1996.
Transmissions to mice indicate that 'new variant' CJD is caused by the BSE agent, Nature, vol.389, pp.498-501, 1997. ,
Transmission of bovine spongiform encephalopathy to sheep and goats, Vet Rec, vol.133, pp.339-341, 1993. ,
Pruritus is a common feature in sheep infected with the BSE agent, BMC Vet Res, vol.4, p.16, 2008. ,
Natural transmission of BSE between sheep within an experimental flock, Vet Rec, vol.157, p.206, 2005. ,
Oral transmission of BSE to VRQ/VRQ sheep in an experimental flock, Vet Rec, vol.162, pp.130-131, 2008. ,
BSE -a wolf in sheep's clothing?, Trends Microbiol, vol.10, pp.563-570, 2002. ,
BSE agent signatures in a goat, Vet Rec, vol.156, pp.523-524, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-02683354
A descriptive study of the prevalence of atypical and classical scrapie in sheep in 20 European countries, BMC Vet Res, vol.4, p.19, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00373589
A review of the epidemiology of scrapie in sheep, Rev Sci Tech, vol.15, pp.827-852, 1996. ,
PrP genetics in ruminant transmissible spongiform encephalopathies, Vet Res, vol.39, p.30, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00902911
The genetics of scrapie in sheep and goats, Curr Mol Med, vol.4, pp.385-396, 2004. ,
Progress and limits of PrP gene selection policy, Vet Res, vol.39, p.25, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00902922
Using genotype probabilities in survival analysis: a scrapie case, Genet Sel Evol, vol.37, pp.403-415, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-02677956
Livestock disease surveys. A field manual for veterinarians, Livestock disease surveys. A field manual for veterinarians, 1982. ,
A new probability formula for surveys to substantiate freedom from disease, Prev Vet Med, vol.34, pp.1-17, 1998. ,
Sense and sensitivity -designing surveys based on an imperfect test, Prev Vet Med, vol.49, pp.141-163, 2001. ,
Demonstrating disease freedom-combining confidence levels, Prev Vet Med, vol.52, pp.227-249, 2002. ,
Evaluation of the cumulative evidence for freedom from BSE in birth cohorts, Eur J Epidemiol, vol.21, pp.47-54, 2006. ,
A model (BSurvE) for estimating the prevalence of bovine spongiform encephalopathy in a national herd, Prev Vet Med, vol.80, pp.330-343, 2007. ,
Demonstrating freedom from disease using multiple complex data sources 1: a new methodology based on scenario trees, Prev Vet Med, vol.79, pp.71-97, 2007. ,
Risk analysis, a quantitative guide 2nd edition, 2000. ,
An efficient algorithm to compute the posterior genotypic distribution for every member of a pedigree without loops, Theor Appl Genet, vol.87, pp.89-93, 1993. ,
Computing approximate monogenic model likelihoods in large pedigrees with loops, Genet Sel Evol, vol.27, pp.567-579, 1995. ,
URL : https://hal.archives-ouvertes.fr/hal-00894117
An approximation to the likelihood for a pedigree with loops, Theor Appl Genet, vol.93, pp.1299-1309, 1996. ,
Efficient computation of genotype probabilities for loci with many alleles: II. Iterative method for large, complex pedigrees, J Anim Sci, vol.79, pp.34-44, 2001. ,
Efficient computation of genotype probabilities for loci with many alleles: I. Allelic peeling, J Anim Sci, vol.79, pp.26-33, 2001. ,
A mathematical model of the dynamics of scrapie in a sheep flock, Math Biosci, vol.153, pp.79-98, 1998. ,
Multiplicative genetic effects in scrapie disease susceptibility, C R Biol, vol.325, pp.565-570, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-02670588
Rapid testing leads to the underestimation of the scrapie prevalence in an affected sheep and goat flock, Vet Microbiol, vol.123, pp.320-327, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00532242
