New interface
Conference papers
Optimal Routing in Parallel, non-Observable Queues and the Price of Anarchy Revisited
Jonatha Anselmi 1, 2 Bruno Gaujal 2
2 MESCAL - Middleware efficiently scalable
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
Abstract : We consider a network of parallel, non-observable queues and analyze the "price of anarchy", an index measuring the worst-case performance loss of a decentralized system with respect to its centralized counterpart in presence of non-cooperative users. Our analysis is undertaken from the new point of view where the router has the memory of previous dispatching choices, which significantly complicates the nature of the problem. In the regime where the demands proportionally grow with the network capacity, we provide a tight lower bound on the socially-optimal response time and a tight upper bound on the price of anarchy by means of convex programming. Then, we exploit this result to show, by simulation, that the billiard routing scheme yields a response time which is remarkably close to our lower bound, implying that billiards minimize response time. To study the added-value of non-Bernoulli routers, we introduce the "price of forgetting" and prove that it is bounded from above by two, which is tight in heavy-traffic. Finally, other structural properties are derived numerically for the price of forgetting. These claim that the benefit of having memory in the router is independent of the network size and heterogeneity, while monotonically depending on the network load only. These properties yield simple product-forms well-approximating the socially-optimal response time.
Complete list of metadata
https://hal.inria.fr/hal-00788888
Contributor : Arnaud Legrand Connect in order to contact the contributor
Submitted on : Friday, February 15, 2013 - 1:11:30 PM
Last modification on : Tuesday, August 2, 2022 - 4:24:52 AM
Links full text
Identifiers
Citation
Jonatha Anselmi, Bruno Gaujal. Optimal Routing in Parallel, non-Observable Queues and the Price of Anarchy Revisited. 22nd International Teletraffic Congress (ITC), 2010, Amsterdam, Netherlands. pp.1-8, ⟨10.1109/ITC.2010.5608745⟩. ⟨hal-00788888⟩
Share
Metrics
Record views
71
