Performance visualization of a transport multi-agent application - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Performance visualization is one of the performance evaluation techniques that can be used to perform a global analysis of a system's behaviour, from its internal point of view. In this work, we describe how a visualization tool, initially designed for classical distributed / parallel systems, has been adapted to visualize the internal behaviour of a multi-agent system. We present such an adaptation though a multi-agent application that can be considered as a typical example for analysis and performance study.
hal-00788925 , version 1 (15-02-2013)
Hussein Joumaa, Yves Demazeau, Jean-Marc Vincent. Performance visualization of a transport multi-agent application. 7th International Conference on Practical Applications of Agents and Multi-Agent Systems, PAAMS09, Mar 2009, Salamanca, Spain. pp.188-196, ⟨10.1007/978-3-642-00487-2_20⟩. ⟨hal-00788925⟩
112 Consultations
0 Téléchargements
