New interface
Journal articles
Atypicity Detection in Data Streams: a Self-Adjusting Approach
Alice Marascu 1 Florent Masseglia 1
1 AxIS - Usage-centered design, analysis and improvement of information systems
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Paris-Rocquencourt
Abstract : Outlyingness is a subjective concept relying on the isolation level of a (set of) record(s). Clustering-based outlier detection is a field that aims to cluster data and to detect outliers depending on their characteristics (i.e. small, tight and/or dense clusters might be considered as outliers). Existing methods require a parameter standing for the "level of outlyingness", such as the maximum size or a percentage of small clusters, in order to build the set of outliers. Unfortunately, manually setting this parameter in a streaming environment should not be possible, given the fast time response usually needed. In this paper we propose WOD, a method that separates outliers from clusters thanks to a natural and effective principle. The main advantages of WOD are its ability to automatically adjust to any clustering result and to be parameterless.
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-00789034
Contributor : Florent Masseglia Connect in order to contact the contributor
Submitted on : Friday, February 15, 2013 - 4:11:02 PM
Last modification on : Thursday, February 3, 2022 - 11:14:04 AM
Long-term archiving on: : Thursday, May 16, 2013 - 4:01:08 AM
File
IDA.pdf
Identifiers
Collections
Citation
Alice Marascu, Florent Masseglia. Atypicity Detection in Data Streams: a Self-Adjusting Approach. Intelligent Data Analysis, 2011, 15 (1), pp.89-105. ⟨10.3233/IDA-2010-0457⟩. ⟨hal-00789034⟩
Share
Metrics
Record views
117
Files downloads
271
