New interface
Journal articles
Scheduling Strategies for Master-Slave Tasking on Heterogeneous Processor Platforms
Cyril Banino 1 Olivier Beaumont 1, 2 Larry Carter 3 Jeanne Ferrante 3 Arnaud Legrand 4 Yves Robert 5
2 SCALAPPLIX - Algorithms and high performance computing for grand challenge applications
INRIA Futurs, Université Bordeaux Segalen - Bordeaux 2, Université Sciences et Technologies - Bordeaux 1, École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB), CNRS - Centre National de la Recherche Scientifique : UMR5800
4 GRAAL - Algorithms and Scheduling for Distributed Heterogeneous Platforms
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
5 REMAP - Regularity and massive parallel computing
Abstract : We consider the problem of allocating a large number of independent, equal-sized tasks to a heterogeneous computing platform. We use a nonoriented graph to model the platform, where resources can have different speeds of computation and communication. Because the number of tasks is large, we focus on the question of determining the optimal steady state scheduling strategy for each processor (the fraction of time spent computing and the fraction of time spent communicating with each neighbor). In contrast to minimizing the total execution time, which is NP-hard in most formulations, we show that finding the optimal steady state can be solved using a linear programming approach and, thus, in polynomial time. Our result holds for a quite general framework, allowing for cycles and multiple paths in the interconnection graph, and allowing for several masters. We also consider the simpler case where the platform is a tree. While this case can also be solved via linear programming, we show how to derive a closed-form formula to compute the optimal steady state, which gives rise to a bandwidth-centric scheduling strategy. The advantage of this approach is that it can directly support autonomous task scheduling based only on information local to each node; no global information is needed. Finally, we provide a theoretical comparison of the computing power of tree-based versus arbitrary platforms.
Complete list of metadata
https://hal.inria.fr/hal-00789427
Contributor : Arnaud Legrand Connect in order to contact the contributor
Submitted on : Monday, February 18, 2013 - 11:49:56 AM
Last modification on : Wednesday, November 30, 2022 - 11:22:07 AM
Identifiers
Collections
Citation
Cyril Banino, Olivier Beaumont, Larry Carter, Jeanne Ferrante, Arnaud Legrand, et al.. Scheduling Strategies for Master-Slave Tasking on Heterogeneous Processor Platforms. IEEE Transactions on Parallel and Distributed Systems, 2004, 15, pp.319―330. ⟨10.1109/TPDS.2004.1271181⟩. ⟨hal-00789427⟩
Share
Metrics
Record views
113
