Complexity Results and Heuristics for Pipelined Multicast Operations on Heterogeneous Platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
We consider the communications involved by the execution of a complex application deployed on a heterogeneous platform. Such applications extensively use macro-communication schemes, such as multicast operations, where messages are broadcast to a set of predefined targets. We assume that there are a large number of messages to be multicast in pipeline fashion, and we seek to maximize the throughput of the steady-state operation. We target heterogeneous platforms, modeled by a graph where links have different communication speeds. We show that the problem of computing the best throughput for a multicast operation is NP-hard, whereas the best throughput to broadcast a message to every node in a graph can be computed in polynomial time. Thus, we introduce several heuristics to deal with this problem and prove that some of them are approximation algorithms. We perform, simulations to test these heuristics and show that their results are close to a theoretical upper bound on the throughput that we obtain with a linear programming approach.
Fichier non déposé
hal-00789448 , version 1 (18-02-2013)
Olivier Beaumont, Arnaud Legrand, Loris Marchal, Yves Robert. Complexity Results and Heuristics for Pipelined Multicast Operations on Heterogeneous Platforms. 2004 International Conference on Parallel Processing (ICPP\'2004), 2004, Unknown, pp.267―274, ⟨10.1109/ICPP.2004.1327931⟩. ⟨hal-00789448⟩
99 Consultations
0 Téléchargements
