Optimal Algorithms for Scheduling Divisible Workloads on Heterogeneous Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
In this paper, we discuss several algorithms for scheduling divisible loads on heterogeneous systems. Our main contributions are (i) new optimality results for single-round algorithms and (ii) the design of an asymptotically optimal multi-round algorithm. This multi-round algorithm automatically performs resource selection, a difficult task that was previously left to the user. Because it is periodic, it is simpler to implement, and more robust to changes in the speeds of the processors and/or communication links. On the theoretical side, to the best of our knowledge, this is the first published result assessing the absolute performance of a multi-round algorithm. On the practical side, extensive simulations reveal that our multi-round algorithm outperforms existing solution on a large variety of platforms, especially when the communication-to-computation ratio is not very high (the difficult case).
Fichier non déposé
hal-00789449 , version 1 (18-02-2013)
Olivier Beaumont, Arnaud Legrand, Yves Robert. Optimal Algorithms for Scheduling Divisible Workloads on Heterogeneous Systems. IPDS'2003, Parallel and Distributed Processing Symposium, 2003, Feb 2003, Nice, France. ⟨10.1109/IPDPS.2003.1213202⟩. ⟨hal-00789449⟩
127 Consultations
0 Téléchargements
