New interface
Conference papers
Load-Balancing Iterative Computations on Heterogeneous Clusters with Shared Communication Links
Abstract : We focus on mapping iterative algorithms onto heterogeneous clusters. The application data is partitioned over the processors, which are arranged along a virtual ring. At each iteration, independent calculations are carried out in parallel, and some communications take place between consecutive processors in the ring. The question is to determine how to slice the application data into chunks, and assign these chunks to the processors, so that the total execution time is minimized. A major difficulty is to embed a processor ring into a network that typically is not fully connected, so that some communication links have to be shared by several processor pairs. We establish a complexity result assessing the difficulty of this problem, and we design a practical heuristic that provides efficient mapping, routing, and data distribution schemes.
Complete list of metadata
https://hal.inria.fr/hal-00789452
Contributor : Arnaud Legrand Connect in order to contact the contributor
Submitted on : Monday, February 18, 2013 - 11:51:44 AM
Last modification on : Tuesday, October 25, 2022 - 4:21:54 PM
Links full text
Identifiers
Citation
Arnaud Legrand, Hélène Renard, Yves Robert, Frédéric Vivien. Load-Balancing Iterative Computations on Heterogeneous Clusters with Shared Communication Links. PPAM-2003: Fifth International Conference on Parallel Processing and Applied Mathematics, 2003, Unknown, pp.930―937, ⟨10.1007/978-3-540-24669-5_120⟩. ⟨hal-00789452⟩
Share
Metrics
Record views
53
