New interface
Conference papers
Scheduling Strategies for Mixed Data and Task Parallelism on Heterogeneous Clusters and Grids
Olivier Beaumont 1, 2 Arnaud Legrand 3 Yves Robert 3
1 SCALAPPLIX - Algorithms and high performance computing for grand challenge applications
INRIA Futurs, Université Bordeaux Segalen - Bordeaux 2, Université Sciences et Technologies - Bordeaux 1, École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB), CNRS - Centre National de la Recherche Scientifique : UMR5800
3 GRAAL - Algorithms and Scheduling for Distributed Heterogeneous Platforms
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : We consider the execution of a complex application on a heterogeneous "Grid" computing platform. The complex application consists of a suite of identical, independent problems to be solved. In turn, each problem consists of a set of tasks. There are dependences (precedence constraints) between these tasks. A typical example is the repeated execution of the same algorithm on several distinct data samples. We use a non-oriented graph to model the Grid platform, where resources have different speeds of computation and communication. We show how to determine the optimal steady-state scheduling strategy for each processor (the fraction of time spent computing and the fraction of time spent communicating with each neighbor). This result holds for a quite general framework, allowing for cycles and multiple paths in the platform graph.
Complete list of metadata
https://hal.inria.fr/hal-00789453
Contributor : Arnaud Legrand Connect in order to contact the contributor
Submitted on : Monday, February 18, 2013 - 11:51:44 AM
Last modification on : Tuesday, October 25, 2022 - 4:23:37 PM
Links full text
Identifiers
Collections
Citation
Olivier Beaumont, Arnaud Legrand, Yves Robert. Scheduling Strategies for Mixed Data and Task Parallelism on Heterogeneous Clusters and Grids. PDP'2003, 11th Euromicro Workshop on Parallel, Distributed and Network-Based Processing, Feb 2003, Gênes, Italy. pp.209―216, ⟨10.1109/EMPDP.2003.1183590⟩. ⟨hal-00789453⟩
Share
Metrics
Record views
120
