Master-Slave Tasking with Heterogeneous Processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Yves Robert
In this paper, we consider the problem of scheduling independent identical tasks on heterogeneous processors where communication times and processing times are different. We assume that communication-computation overlap is possible for every processor, but only allow one send and one receive at a time. We propose an algorithm for chains of processors based on an iterative backward construction of the schedule, which is polynomial in the number of processors and in the number of tasks. The complexity is O(np2) where n is the number of tasks and p the number of processors. We prove this algorithm to be optimal with respect to the makespan. We extend this result to a special kind of tree called spider graphs.
Fichier non déposé
hal-00789462 , version 1 (18-02-2013)
Olivier Beaumont, Arnaud Legrand, Yves Robert. Master-Slave Tasking with Heterogeneous Processors. 2001 International Conference on Parallel and Distributed Processing Techniques and Applications (PDPTA\'2001), 2001, Unknown, pp.857―863, ⟨10.1109/IPDPS.2003.1213103⟩. ⟨hal-00789462⟩
71 Consultations
0 Téléchargements
