New interface
Conference papers
$CC_SCR$: Compression Cluster-based scheme in a Spatial Correlated Region for Wireless Sensor Networks
Sofiane Moad 1 Mario Rivero 2 Nizar Bouabdallah 1 Rami Langar 3
1 DIONYSOS - Dependability Interoperability and perfOrmance aNalYsiS Of networkS
Inria Rennes – Bretagne Atlantique , IRISA-D2 - RÉSEAUX, TÉLÉCOMMUNICATION ET SERVICES
3 Phare
LIP6 - Laboratoire d'Informatique de Paris 6
Abstract : In this paper, we propose a new Compression Cluster-based scheme in a Spatial Correlated Region (CC_SCR) for event-driven applications in wireless sensor networks. The main idea behind our proposal is to exploit the spatial correlation of such networks in order to reduce the size of the data packets that will be sent by means of data compression. The proposed clustering scheme is based on selecting a data value as reference while the rest of the active nodes transmit only the difference between their sensed value and this reference value. Hence, one major issue in the proposed mechanism is to appropriate select the reference node that achieves the highest reduction of the packet size among all active nodes. The CC_SCR protocol is evaluated by simulations. The results show that CC_SCR may reduce as much as 11 times the energy consumption compared to a classical clustering scheme.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00789642
Contributor : Anne Jaigu Connect in order to contact the contributor
Submitted on : Monday, February 18, 2013 - 3:21:56 PM
Last modification on : Thursday, January 20, 2022 - 5:29:20 PM
Identifiers
Citation
Sofiane Moad, Mario Rivero, Nizar Bouabdallah, Rami Langar. $CC_SCR$: Compression Cluster-based scheme in a Spatial Correlated Region for Wireless Sensor Networks. IEEE International Conference on Communications, ICC 2011, Jun 2011, Kyoto, Japan. pp.1-6, ⟨10.1109/icc.2011.5962643⟩. ⟨hal-00789642⟩
Share
Metrics
Record views
143
