Constrained Diffusion Kurtosis Imaging Using Ternary Quartics and MLE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a ternary quartic based approach with an improved gradient based optimization scheme for diffusion kurtosis imaging to estimate constrained and physically realistic diffusion and kurtosis tensors. We account for the signal noise by considering a maximum likelihood estimation based on the Rician noise model. Diffusion kurtosis imaging (DKI) is a recent important improvement over the diffusion tensor imaging (DTI) model that quantifies the degree of non-Gaussian diffusion in a tissue using a 3D 4th order tensor. However, DKI estimation needs to consider three constraints to be physically relevant. By adopting the implicit ternary quartic parameterization which allows to elegantly impose a positivity constraint on the kurtosis tensor and by employing gradient based optimization schemes, we show dramatically improved performance in terms of estimation time and quality. We derive the mathematical framework and show results on extensive synthetic data experiments.
Fichier non déposé
hal-00789755 , version 1 (18-02-2013)
  • HAL Id : hal-00789755 , version 1
Tristan Milne, Aurobrata Ghosh, Rachid Deriche. Constrained Diffusion Kurtosis Imaging Using Ternary Quartics and MLE. Computational Diffusion MRI Workshop (CDMRI), 2012, MICCAI, 2012, Nice, France. pp.153―164. ⟨hal-00789755⟩
146 Consultations
0 Téléchargements
