Fast multilevel implementation of recursive spectral bisection for partitioning unstructured problems, Concurrency: Practice and Experience, vol.38, issue.2, pp.101-117, 1994. ,
DOI : 10.1002/cpe.4330060203
A repartitioning hypergraph model for dynamic load balancing. Sandia National Laboratories Tech, 2008. ,
DOI : 10.1016/j.jpdc.2009.04.011
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.150.7782
Hypergraph-based dynamic partitioning and load balancing. Sandia National Laboratories Tech, 2007. ,
DOI : 10.1002/9780470558027.ch15
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.150.7492
A repartitioning hypergraph model for dynamic load balancing, J. Parallel Distrib. Comput, vol.69, pp.711-724, 2009. ,
Improvement of the Efficiency of Genetic Algorithms for Scalable Parallel Graph Partitioning in a Multi-level Framework, Proc. Euro-Par'06, pp.243-252, 2006. ,
DOI : 10.1007/11823285_25
URL : https://hal.archives-ouvertes.fr/hal-00402946
PT-Scotch: A tool for efficient parallel graph ordering, Parallel Computing, vol.34, issue.6-8, pp.318-331, 2008. ,
DOI : 10.1016/j.parco.2007.12.001
URL : https://hal.archives-ouvertes.fr/hal-00402893
Dynamic load balancing for distributed memory multiprocessors, Journal of Parallel and Distributed Computing, vol.7, issue.2, pp.279-301, 1989. ,
DOI : 10.1016/0743-7315(89)90021-X
A linear-time heuristic for improving network partitions, Proc. 19th Design Automat. Conf, pp.175-181, 1982. ,
Computers and Intractablility: A Guide to the Theory of NP-completeness, 1979. ,
Skewed graph partitioning, Proceedings of the 8 th SIAM Conference on Parallel Processing for Scientific Computing, 1997. ,
An optimal migration algorithm for dynamic load balancing. concurrency: Practice and experience, 1998. ,
ParMetis Parallel Graph Partitioning and Sparse Matrix Ordering Library, 2003. ,
DOI : 10.1006/jpdc.1997.1403
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.127.896
A new diffusion-based multilevel algorithm for computing graph partitions, Journal of Parallel and Distributed Computing, vol.69, issue.9, pp.750-761, 2009. ,
DOI : 10.1016/j.jpdc.2009.04.005
PLUM : Parallel Load Balancing for Adaptive Unstructured Meshes, Journal of Parallel and Distributed Computing, vol.52, issue.2, pp.150-177, 1998. ,
DOI : 10.1006/jpdc.1998.1469
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.158.9552
Static mapping by dual recursive bipartitioning of process architecture graphs, Proceedings of IEEE Scalable High Performance Computing Conference, pp.486-493, 1994. ,
DOI : 10.1109/SHPCC.1994.296682
A Parallelisable Multi-level Banded Diffusion Scheme for Computing Balanced Partitions with Smooth Boundaries, Proc. Euro-Par'07, pp.191-200, 2007. ,
DOI : 10.1007/978-3-540-74466-5_22
URL : https://hal.archives-ouvertes.fr/hal-00301427
Parallel multilevel diffusion algorithms for repartitioning of adaptive meshes, 1997. ,
Wavefront diffusion and LMSR: algorithms for dynamic repartitioning of adaptive meshes, IEEE Transactions on Parallel and Distributed Systems, vol.12, issue.5, pp.451-466, 2001. ,
DOI : 10.1109/71.926167
Variable Partition Inertia: Graph Repartitioning and Load Balancing for Adaptive Meshes, Advanced Computational Infrastructures for Parallel and Distributed Adaptive Applications, 2010. ,
DOI : 10.1002/9780470558027.ch17
Parallel optimisation algorithms for multilevel mesh partitioning, Parallel Computing, vol.26, issue.12, 2000. ,
DOI : 10.1016/S0167-8191(00)00046-6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.15.502
Dynamic Mesh Partitioning and Load-Balancing for Parallel Computational Mechanics Codes, Computational Mechanics Using High Performance Computing, pp.79-94, 2002. ,
DOI : 10.4203/csets.9.4
Parallel Dynamic Graph Partitioning for Adaptive Unstructured Meshes, Journal of Parallel and Distributed Computing, vol.47, issue.2, pp.102-108, 1997. ,
DOI : 10.1006/jpdc.1997.1407
(>) med: 0.00526 quantiles: [0.0027837, 0.0070225] ratio: 1.21411 prop: 96.86 % (>) med: 0.0061745 quantiles: [0.0030138, 0.008021] ratio: 1.2478 prop: 97.00 % (>) med: 0 (>) med: ?0, Proc. Swarm Intelligence Symposium, pp.273-280, 2005. ,
