Workflow Resiliency for Large-Scale Distributed Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Large-scale simulation and optimization are demanding applications that require high-performance computing platforms. Because their economic impact is fundamental to the industry, they also require robust, seamless and effective mechanisms to support dynamic user interactions, as well as fault-tolerance and resiliency on parallel computing platforms. Distributed workflows are considered here as a means to support large-scale dynamic and resilient multiphysics simulation and optimization applications, such as multiphysics aircraft simulation.
Fichier non déposé
hal-00790509 , version 1 (20-02-2013)
Toan Nguyen, Jean-Antoine Desideri, Vittorio Selmin. Workflow Resiliency for Large-Scale Distributed Applications. ADVCOMP - Third International Conference on Advanced Engineering Computing and Applications in Sciences, IEEE, Oct 2009, Sliema, Malta. pp.7-12, ⟨10.1109/ADVCOMP.2009.9⟩. ⟨hal-00790509⟩
137 Consultations
0 Téléchargements
