Convergence Speed of Unsteady Distributed Consensus: Decay Estimate Along the Settling Spanning-Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2009
Results for estimating the convergence rate of nonstationary distributed consensus algorithms are provided, on the basis of qualitative (mainly topological) as well as basic quantitative information (lower-bounds on the matrix entries). The results appear to be tight in a number of instances and are illustrated through simple as well as more sophisticated examples. The main idea is to follow propagation of information along certain spanning-trees which arise in the communication graph.
hal-00793004 , version 1 (21-02-2013)
David Angeli, Pierre-Alexandre Bliman. Convergence Speed of Unsteady Distributed Consensus: Decay Estimate Along the Settling Spanning-Trees. SIAM Journal on Control and Optimization, 2009, 48 (1), pp.1-32. ⟨10.1137/060673527⟩. ⟨hal-00793004⟩
Collections
INRIA INRIA2
171 Consultations
0 Téléchargements
