Efficient parameter search for qualitative models of regulatory networks using symbolic model checking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioinformatics Année : 2010
Motivation: Investigating the relation between the structure and behavior of complex biological networks often involves posing the question if the hypothesized structure of a regulatory network is consistent with the observed behavior, or if a proposed structure can generate a desired behavior. Results: The above questions can be cast into a parameter search problem for qualitative models of regulatory networks. We develop a method based on symbolic model checking that avoids enumerating all possible parametrizations, and show that this method performs well on real biological problems, using the IRMA synthetic network and benchmark datasets. We test the consistency between IRMA and time-series expression profiles, and search for parameter modifications that would make the external control of the system behavior more robust.
hal-00793024 , version 1 (21-02-2013)
Gregory Batt, Michel Page, Irene Cantone, Gregor Goessler, Pedro T. Monteiro, et al.. Efficient parameter search for qualitative models of regulatory networks using symbolic model checking. Bioinformatics, 2010, 26, pp.i603-i610. ⟨10.1093/bioinformatics/btq387⟩. ⟨hal-00793024⟩
364 Consultations
0 Téléchargements
