Uniform convergence for complex [0, 1]-martingales - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Annals of Applied Probability Année : 2010
Positive T-martingales were developed as a general framework that extends the positive measure-valued martingales and are meant to model intermittent turbulence. We extend their scope by allowing the martingale to take complex values. We focus on martingales constructed on the interval T = [0, 1] and replace random measures by random functions. We specify a large class of such martingales for which we provide a general sufficient condition for almost sure uniform convergence to a nontrivial limit. Such a limit yields new examples of naturally generated multifractal processes that may be of use in multifractal signals modeling.
hal-00793058 , version 1 (21-02-2013)
Julien Barral, Xiong Jin, Benoît Mandelbrot. Uniform convergence for complex [0, 1]-martingales. The Annals of Applied Probability, 2010, 20 (4), pp.1205-1218. ⟨10.1214/09-AAP664⟩. ⟨hal-00793058⟩
113 Consultations
0 Téléchargements
