Dynamics of Mandelbrot cascades - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Probability Theory and Related Fields Année : 2009
Mandelbrot multiplicative cascades provide a construction of a dynamical system on a set of probability measures de ned by inequalities on moments. To be more speci c, beyond the rst iteration, the trajectories take values in the set of xed points of smoothing transformations (i.e., some generalized stable laws). Studying this system leads to a central limit theorem and to its functional version. The limit Gaussian process can also be obtained as limit of an 'additive cascade' of independent normal variables.
hal-00793170 , version 1 (21-02-2013)
Julien Barral, Jacques Peyrière, Zhi-Ying Wen. Dynamics of Mandelbrot cascades. Probability Theory and Related Fields, 2009, 144 (3-4), pp.615-631. ⟨10.1007/s00440-008-0156-8⟩. ⟨hal-00793170⟩
54 Consultations
0 Téléchargements
