Interferer Link-Aware Routing in Wireless Mesh Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rami Langar
Raouf Boutaba
Guy Pujolle
This paper presents a new metric for routing in wireless mesh networks (WMNs). The proposed metric does not only consider the quality of wireless links to choose a high throughput path between a pair of nodes, but it also includes the resulting interference introduced by using such links. The philosophy behind this metric is to choose a good path for an arriving connection, not necessarily the best in terms of throughput, but that alleviates the resulting interference in order to preserve good paths for the subsequent arriving connections. In doing so, we find that our metric significantly outperforms previously proposed routing metrics when multiple concurrent flows are considered in the network. The total network throughput is indeed increased.
Fichier non déposé
hal-00793310 , version 1 (22-02-2013)
Rami Langar, Nizar Bouabdallah, Raouf Boutaba, Guy Pujolle. Interferer Link-Aware Routing in Wireless Mesh Networks. IEEE International Communications Conference (IEEE ICC 2010), May 2010, Cape Town, South Africa. pp.1-6, ⟨10.1109/ICC.2010.5502159⟩. ⟨hal-00793310⟩
220 Consultations
0 Téléchargements
