Modelling and analysing reliable service-oriented processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Business Process Integration and Management Année : 2009
This paper introduces principled methods for the reliability analysis of business processes that rely on web services. The input to the problem is the BPEL specification of a business process and the output is the prediction of the process's reliability. The first step to this end involves a method for the translation of the BPEL specification to its corresponding UML model. The second step of the reliability analysis involves a principled way for the annotation of the UML model with the necessary extensions for the specification of reliability properties that characterise the behaviour of the elements that constitute the process. The third step of the analysis comprises the systematic mapping of the extended UML model to block diagrams and Markov models which are subsequently used to compute the reliability of the process.
Fichier non déposé
hal-00793382 , version 1 (22-02-2013)
Apostolos Zarras, Panos Vassiliadis, Valérie Issarny. Modelling and analysing reliable service-oriented processes. International Journal of Business Process Integration and Management, 2009, 3 (3), pp.147-163. ⟨10.1504/IJBPIM.2008.023216⟩. ⟨hal-00793382⟩
Collections
INRIA INRIA2
48 Consultations
0 Téléchargements
