Performance-constrained Distributed DVS Scheduling for Scientific Applications on Power-aware Clusters, ACM/IEEE SC 2005 Conference (SC'05), 2005. ,
DOI : 10.1109/SC.2005.57
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.101.1233
Temperature-aware microarchitecture, ACM Transactions on Architecture and Code Optimization, vol.1, issue.1, pp.94-125, 2004. ,
DOI : 10.1145/980152.980157
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.135.9559
Grid Computing: Making The Global Infrastructure a Reality, chap. Parameter Sweeps on the Grid with APST, 2003. ,
Optimal sharing of bags of tasks in heterogeneous clusters, Proceedings of the fifteenth annual ACM symposium on Parallel algorithms and architectures , SPAA '03, pp.1-10, 2003. ,
DOI : 10.1145/777412.777414
Energy-Aware Scheduling of Flow Applications on Master-Worker Platforms, Proceedings of Euro-Par 2009, pp.281-292, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01064145
Distributed adaptive task allocation in heterogeneous computing environments to maximize throughput, 18th International Parallel and Distributed Processing Symposium, 2004. Proceedings., 2004. ,
DOI : 10.1109/IPDPS.2004.1302974
Adaptive Allocation of Independent Tasks to Maximize Throughput, IEEE Transactions on Parallel and Distributed Systems, vol.18, issue.10, pp.1420-1435, 2007. ,
DOI : 10.1109/TPDS.2007.1042
Communication-aware scheduling on heterogeneous master-worker platforms, 2008. ,
URL : https://hal.archives-ouvertes.fr/tel-00530131
Profile-based optimization of power performance by using dynamic voltage scaling on a PC cluster, Proceedings 20th IEEE International Parallel & Distributed Processing Symposium, 2006. ,
DOI : 10.1109/IPDPS.2006.1639597
Combined dynamic voltage scaling and adaptive body biasing for lower power microprocessors under dynamic workloads, Proceedings of the IEEE/ACM International Conference on Computer-Aided Design (ICCAD), ACM, pp.721-725, 2002. ,
DOI : 10.1145/774572.774678
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.308.5075
Overhead-conscious voltage selection for dynamic and leakage energy reduction of time-constrained systems, Proceedings of the conference on Design, Automation and Test in Europe (DATE), p.518, 2004. ,
Energy-efficient algorithms for flow time minimization, ACM Transactions on Algorithms, vol.3, issue.4, p.49, 2007. ,
DOI : 10.1145/1290672.1290686
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.486.9081
Dynamic Speed Scaling to Manage Energy and Temperature, 45th Annual IEEE Symposium on Foundations of Computer Science, pp.520-529, 2004. ,
DOI : 10.1109/FOCS.2004.24
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.65.7024
Power-aware scheduling for makespan and flow, Proceedings of the ACM Symposium on Parallelism in Algorithms and Architectures (SPAA), pp.190-196, 2006. ,
DOI : 10.1145/1148109.1148140
URL : http://arxiv.org/abs/cs/0605126
Energy-Aware Scheduling of Flow Applications on Master-Worker Platforms, 2008. ,
Speed Scaling for Weighted Flow Time, Proceedings of the ACM- SIAM Symposium On Discrete Algorithms (SODA), pp.805-813, 2007. ,
DOI : 10.1137/08072125X
Communication-aware task scheduling and voltage selection for total systems energy minimization, ICCAD-2003. International Conference on Computer Aided Design (IEEE Cat. No.03CH37486), 2003. ,
DOI : 10.1109/ICCAD.2003.159732
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.112.5811
Voltage scheduling problem for dynamically variable voltage processors, Proceedings of the 1998 international symposium on Low power electronics and design , ISLPED '98, pp.197-202, 1998. ,
DOI : 10.1145/280756.280894
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.2.9415
Real-time task scheduling for a variable voltage processor, Proceedings 12th International Symposium on System Synthesis, 1999. ,
DOI : 10.1109/ISSS.1999.814256
Energy minimization of real-time tasks on variable voltage processors with transition energy overhead, Proceedings of the 2003 conference on Asia South Pacific design automation , ASPDAC, pp.65-70, 2003. ,
DOI : 10.1145/1119772.1119786
Energy efficient fixed-priority scheduling for real-time systems on variable voltage processors, Proceedings of the 38th conference on Design automation , DAC '01, pp.828-833, 2001. ,
DOI : 10.1145/378239.379074
Energy efficient online deadline scheduling, Proceedings of the ACM-SIAM Symposium On Discrete Algorithms (SODA), pp.795-804, 2007. ,
Energy-Efficient Real-Time Task Scheduling with Task Rejection, 2007 Design, Automation & Test in Europe Conference & Exhibition, pp.1629-1634, 2007. ,
DOI : 10.1109/DATE.2007.364535
Scheduling with dynamic voltage/speed adjustment using slack reclamation in multiprocessor real-time systems, IEEE Transactions on Parallel and Distributed Systems (TPDS), vol.14, issue.7, pp.686-700, 2003. ,
Multi-version scheduling in rechargeable energy-aware real-time systems, Journal of Embedded Computing, vol.1, issue.2, pp.271-283, 2005. ,
Energy-Efficient Task Partition for Periodic Real-Time Tasks on Platforms with Dual Processing Elements, 2008 14th IEEE International Conference on Parallel and Distributed Systems, 2008. ,
DOI : 10.1109/ICPADS.2008.123
A Near-optimal Solution for the Heterogeneous Multi-processor Single-level Voltage Setup Problem, 2007 IEEE International Parallel and Distributed Processing Symposium, 2007. ,
DOI : 10.1109/IPDPS.2007.370247
Power-aware resource allocation for independent tasks in heterogeneous real-time systems, International Conference on Parallel and Distributed Systems (ICPADS), pp.341-348, 2002. ,
Allocation cost minimization for periodic hard real-time tasks in energy-constrained dvs systems, Proceedings of the IEEE/ACM International Conference on Computer-Aided Design (ICCAD), pp.255-260, 2006. ,
Multiprocessor synthesis for periodic hard real-time tasks under a given energy constraint, Proceedings of the conference on Design, Automation and Test in Europe (DATE), European Design and Automation Association, pp.1061-1066, 2006. ,
Grid'5000: A large scale, reconfigurable, controlable and monitorable grid platform, Proceedings of the 6th IEEE/ACM International Workshop on Grid Computing (Grid'2005), 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00000284
